universal reflection control help
By brit · 2013-11-18
trying to create a universal reflection control for a arch-design material
here is what i have got, any help would be great, cheers :-
try(destroydialog ::weeevel)catch()
rollout weeevel "Universal Reflect" width:161 height:140
spinner dist "Reflect weight" pos:[22,31] width:116 height:16 enabled:true range:[0,100,0]
spinner samples "Reflect samples" pos:[22,52] width:116 height:16 enabled:true range:[0,100,0]
button Enable "Enable refl" pos:[19,81] width:116 height:20
on Enable pressed do
for a in objects do
if (classof a.material == Arch___Design__mi) then
a.material.refl_weight = dist.value
a.material.refl_samples = samples.value
if (classof a.material == Multimaterial) then
for b = 1 to a.material.numsubs do
if (classof a.material.materialList[b] == Arch___Design__mi) then
a.material.materialList[b].refl_weight = dist.value
a.material.materialList[b].refl_samples = samples.value
CreateDialog weeevel 161 140 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Comments (8)
Daniel
awesome! great work that was what I needed.
some control can be added... like AO and displace parameters...
brit
got it to work:-
m.bump_map_on = bmp.state
instead of
m.bump_map_on = off
Reply to brit
or U can use button and ...
on btn pressed do (m.bump_map_on = not m.bump_map_on)
brit
trying to add a global bump on/off checkbox
i have managed to creat the off but the toggle im stuck on, cheers:-
rollout weeevel "Universal Material" width:161 height:266
spinner refl_weight "Reflect weight : " pos:[5,31] width:155 height:16 range:[0,100,0.6] fieldwidth:60
spinner refl_gloss "Reflect glossy : " pos:[4,52] width:156 height:16 range:[0,100,1] fieldwidth:60
spinner refl_samples "Reflect samples : " pos:[5,73] width:156 height:16 range:[0,100,8] fieldwidth:60
button Enable "Enable reflection" pos:[5,94] width:158 height:21
checkbox bmp "bump on/off" pos:[8,123] width:146 height:29 triState:1
ad_Mtls = getClassInstances Arch___Design__mi
if ad_Mtls.count != 0 do
for m in ad_Mtls do
m.refl_weight = refl_weight.value
m.refl_gloss = refl_gloss.value
m.refl_samples = refl_samples.value
on bmp changed triState do
for m in ad_Mtls do
m.bump_map_on = off
CreateDialog weeevel 168 200 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Reply to brit
It's better to use this concept
rollout weeevel "Universal A&D" width:161 height:140
local ad_Mtls = #()
label title " Arch && Design Properties" pos:[5,5] width:158 height:18 style_sunkenedge:on
spinner refl_weight "Reflect Weight : " pos:[5,31] fieldwidth:60 range:[0,100,0.6]
spinner refl_gloss "Reflect Glossy : " pos:[4,52] fieldwidth:60 range:[0,100,1]
spinner refl_samples "Reflect Samples : " pos:[5,73] fieldwidth:60 range:[0,100,8]
button btn_reflection "Set Reflection" pos:[5,94] width:158
checkbox bump_map_on "Bump On/Off" pos:[5,120] width:80 checked:on
spinner bump_map_amt "" pos:[91,120] fieldwidth:60 range:[-10,10,.3]
checkbox no_diffuse_bump "No Diffuse Bump Shading" pos:[5,136] checked:off
button btn_bump "Set Bump" pos:[5,154] width:158
on btn_reflection pressed do
for m in ad_Mtls do
) ; free ad_Mtls
on btn_bump pressed do
for m in ad_Mtls do
m.bump_map_on = bump_map_on.checked
m.bump_map_amt = bump_map_amt.value
m.no_diffuse_bump = no_diffuse_bump.checked
) ; free ad_Mtls
on bump_map_on changed state do bump_map_amt.enabled = state
CreateDialog weeevel 168 180 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
My pleasure
brit
Thanks you Barigazy, this is great, very much appreciated.
spinner refl_weight "Reflect weight : " pos:[5,31] fieldwidth:60 range:[0,100,0.6]
spinner refl_gloss "Reflect glossy : " pos:[4,52] fieldwidth:60 range:[0,100,1]
spinner refl_samples "Reflect samples : " pos:[5,73] fieldwidth:60 range:[0,100,8]
for m in ad_Mtls do
CreateDialog weeevel 168 120 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
