I want to make a function that generates a random number while excluding a given number.
Example:
generate a random number between 0 - 2 until it is not equal to 1
then return that value
not exactly working....
fn generateRandomNumber = (
rNum = random 0 2
if rNum == 1 do (
generateRandomNumber()
return rNum
Comments (9)
Does this seem right?
I'll have to put a check in here incase the min and max values are the same. otherwise it crashes.
arr = #([0,0,0],[1,1,1],[2,2,2],[3,3,3],[4,4,4],[5,5,5])
disMin = 1
disMax = 4
fn fnRandomLimited arr usedIdx =
numItms = arr.count
usedItm = arr[usedIdx]
num = arr[usedIdx]
while num == arr[usedIdx] AND distance num usedItm <= disMin OR distance num usedItm >= disMax do
num = arr[random 1 numItms]
print (distance num usedItm)
return num
clearlistener()
fnRandomLimited arr 4
--find a point three value in the given array which doesn't match the "currently used item in the same array"
Find unused p3 value in array
I don't know, maybe this or i'm wrong.
arr = #([0,0,0],[1,1,1],[2,2,2],[3,3,3],[4,4,4],[5,5,5])fn fnRandomLimited arr usedIdx =
local p3 = [0,0,0]
while finditem arr arr[random 1 arr.count] != usedIdx do
p3 = arr[random 1 arr.count]
format "p3=%\n" p3
Check this out.
It's what I needed it for.
http://jokermartini.com/2012/05/09/cobwebs/
Thanks for you help.
I really appreciate it.
Can I ask you what do you need this stopRandom FN?
Are you still have a problem with the "intersection in time"?
I just saw. For the Cobwebs script. Fantastic idea :)
StopRandom FN
Hi John,
If I understood you well, this is what you looking for
fn stopRandom n:3 r1:0 r2:10 =
num = 0
x = 3
while num != n do
num = random r1 r2
format "num=%\n" num
Why the x = 0?Here is a
Why the x = 0?
Here is a revision to it.
Check it out.
fn fnUniqueRandom range:[0,3,2] =
num = range[3]
while num == range[3] do
num = random (range[1] as integer) (range[2] as integer)
return num
clearlistener()
fnUniqueRandom range:[0,2,1]
Sorry i forgot to remove it. :)
If you need round float use
But you probably know this already:)
