Hello everyone!
I have a problem, i can't find a way how to switch viewport grid color from color value to intensity value.
In Max customization window - you could select the method of coloring of grid by color or by intensity.
And the question how to do this with max script?
So grid by color SetUIColor 3 () by intensity SetUIColor 4 () but if you select in customize window for example "grid by intensity" in this case the function grid by color will not work.
May be your problem can be resolved by using:- Standard menu: Customize menu > Customize User Interface > Colors tab
Customize menu > Customization > Customize User Interface > Colors tab
If this does not work, I will try another way for the solution of the problem.
