I get this error, if even BitmapLister is global! Please HELP!!!!
Here is the script:
macroScript Bitmaps
category: "artrender"
try(destroydialog ::BitmapLister)catch()
bitmaps=#()
GLOBAL BitmapLister
cur_obj_selection=#()
BitmapLister_iso_x = getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_x" as integer
BitmapLister_iso_y = getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_y" as integer
BitmapLister_size_h = (if (tmp = (getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_h" as integer)) == 0 then 324 else tmp)
BitmapLister_size_w = (if (tmp = (getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_w" as integer)) == 0 then 152 else tmp)
numBitmaps = 0
function enable_event = (
callbacks.addScript #selectionSetChanged "check_selection()" id:#m3dLearnEvent
function disable_event = (
callbacks.RemoveScripts #selectionSetChanged id:#m3dLearnEvent
function check_selection = (
this_sel_count = (selection as array).count
BitmapLister.lbl_num_picked.text = "num picked: " + (this_sel_count as string)
rollout BitmapLister "Maps" width:231 height:65
label lbl_num_picked "Num Picked: 0" pos:[380,20] width:62 height:40
dotNetControl lv "System.Windows.Forms.ListView" width:657 height:200 pos:[5,100]
on BitmapLister close do (
disable_event()
setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_x" ((GetDialogPos BitmapLister).x as string)
setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_y" ((GetDialogPos BitmapLister).y as string)
setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_w" ((GetDialogSize BitmapLister).x as string)
setinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_h" ((GetDialogSize BitmapLister).y as string)
on BitmapLister open do
check_selection()
enable_event()
createdialog BitmapLister pos:[BitmapLister_iso_x,BitmapLister_iso_y] height:(BitmapLister_size_h) width:(BitmapLister_size_w) style:#(#style_resizing,#style_sysmenu,#style_titlebar)
Comments (7)
I'll worry about your
function.
It s'd be visible for
Also maybe is good to make it more robust:
And I'll suggets to move functions
and
inside BitmapLister rollout, and then the last command in those function will become:
i.e.:
Yep. you are right. No need to be outside roll definition.
example
local bitmaps=#(), cur_obj_selection=#(), numBitmaps = 0
local BitmapLister_iso_x = 10 --getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_x" as integer
local BitmapLister_iso_y = 110 --getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "pos_y" as integer
local BitmapLister_size_h = 230 --(if (tmp = (getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_h" as integer)) == 0 then 324 else tmp)
local BitmapLister_size_w = 310 --(if (tmp = (getinisetting "$plugcfg\\RacoonScripts.ini" "BitmapLister" "size_w" as integer)) == 0 then 152 else tmp)
fn initListView lv =
lv.fullRowSelect = lv.gridLines = true
lv.View = (dotNetClass "View").Details
layout_def = #("Object Name", "Object Class", "Wirecolor")
for i in layout_def do lv.Columns.add i 100
fn fillInList lv = if selection.count != 0 do
local selectionNames = #() --array to collect the list items
for o in selection do
li = dotNetObject "ListViewItem" o.name
sub_li = li.SubItems.add ((classof o) as string)
sub_li = li.SubItems.add (o.wirecolor as string)
append selectionNames li
lv.Items.AddRange selectionNames
fn enable_event = (callbacks.addScript #selectionSetChanged "check_selection()" id:#m3dLearnEvent)
fn disable_event = callbacks.RemoveScripts #selectionSetChanged id:#m3dLearnEvent
fn check_selection =
this_sel_count = selection.count
BitmapLister.lbl_num_picked.text = " Num Picked: " + (this_sel_count as string)
fillInList BitmapLister.lv
label lbl_num_picked " Num Picked: 0" pos:[5,5] width:80 height:20
dotNetControl lv "ListView" width:300 height:200 pos:[5,30]
disable_event()
initListView BitmapLister.lv
check_selection() ; disable_event() ; enable_event()
createdialog BitmapLister BitmapLister_size_w BitmapLister_size_h BitmapLister_iso_x BitmapLister_iso_y style:#(#style_resizing,#style_sysmenu,#style_titlebar)
STILL THE SAME ERROR
I want to thank you for this help! Srry that I disturb you, but I've tried your code at two computers, and it's giving the same error! I've tried to put after this GLOBAL BitmapLister and it does not help also! Please, tell me! The error appears after selecting any object in scene!
Also, restart 3d max (not reset), and try! It may happen that after many times of trying in the same scene, it could start working! this happend to my previous scripts! But they should work even from the start!
try now
global BitmapLister
global enable_event, disable_event, check_selection
try(destroydialog BitmapLister)catch()
lv.items.clear()
disable_event()
disable_event()
check_selection()
enable_event()
THANK YOUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUUU!
I'M SO HAPPY! THANK YOU, BARIGAZYYYYYYYYYYYYYYYYYYY!
Cheers dude!
