TV screen object
By locb · 2023-11-27
Hello.
I need a script that would create a new object, the screen based on the size of the diagonal and the thickness of the frame and depth of the object, the ratio of 16x9 or 16:10. or 4:3.
For example, I enter a diagonal of 55" and a frame of 1cm and a depth of 4cm.
And the script creates a rectangle 1218mm x 685mm, adds 1cm thickness to it and adds 4cm volume.
How can this be done?
locb
WOW
just saw the comment.
This is something that will save me a lot of time.
Thank you so much.
Reply to locb
Simon Bourgeois
You're welcome
lol, almost a year later :)
Glad i could help
Cheers
Simon Bourgeois
AutoScreen
Hello,
here is the Script you need:
https://www.mediafire.com/file/12dvxejss2wu7u7/SimonScripts-AutoScreen_V…
When you press the button you will be prompted to browse for an image or multiple images then it will create a screen for each images, if the images aren't at the right ratio the uvw modifier will be set accordingly to fit the screen and not distort the image.
it works for Vray and Corona if set to Standard it will create Physical materials.
