a=for i in objects collect a
for i in a do print a
result is
$Box:Box01 @ [-58.061844,32.259445,0.000000]
$Box:Box02 @ [8.451210,6.026428,0.000000]
OK <--- here is wrong
the question is how to make the result not using "ok" string just object in array as list like
can some one help me please
thanks and best regard
fajar
yes , youre correct anubisi
i use
aha, so the problem is different then :)
I'm not sure whether we can edit the name of our topic, but try anyway to change it to "passing multiple objects to mouseTrack function".
what do you mean by that anubis , could you give me more light ?
@swordplayer :
thanks for that but im not looking for something like that.
@ all
I want to try writte script "autogrid like" but not grid-ed only in on one selected object available but all objects. I use mousetrack function, standard-ly when using mouse track its only using pick one object, or select target object as surface, but im trying to make all object available to as surface. so instead say something like
im try
thanks for understanding and thanks for answering my question
best regard
fajar
EDIT = Resolved
Hi Fajar
is a collection,
maybe you ask for this one:
That's because maxscript listener receives not only the output of print and format commands but also all the return values (and maxscript, being expression-based language, always returns something, whether it's OK, undefined or some other value). If you want to get just the text, send it to some sort of stream, for example:
