Hi. This time, I wanted my script to change the scene render size using data from Edit Box, but I have a hard time converting it to integer or something that would work. Google has been frugal about information on this matter, so I ask here.
Here's a part of the code:
editText set_w "W" pos:[20,85] width:80 height:17 text:"640"
on set_w changed text do
renderWidth = int set_w.text
This generates an error "-- Unable to convert "MY ACTUAL INPUT NUMBER" to type: Integer". When I change the syntax to:
renderWidth = int $.set_w.text
it gives me an "-- Unknown property: "set_w" in undefined" error. I played with brackets (selecting whole or a part of it), modifying the syntax about a hundred time but with no effect. I'm pretty good at generating errors though. :)
Any help much appreciated!
Thanks in advance.
(PS. Let me add that I'm working on 3DS Max 2009 x64, just for clarification.)
Answer, already?
Wow, that was quick. I found some solution already. :P
Channing only this part:
done wonders.
Posting on this forum is marvelous, if I didn't write I probably wouldn't come to this solution anyway.
