Transform control with MaxScript.
I controlled the transform of the object.
Position = point3
Rotation = Quat
Scale = point3
This worked correctly.
However, if a child exists in the object, the child moves strangely.
For example
Parent Position: 0,0,0
Child's position: 0,0,1
In this situation, if you use the viewport control and move the parent to 1, 0, 0, the children are in positions 1, 0, 1
However, when I move using the script, the child's position is 1,0,0.
What is the problem?
By P_MAN · 2018-09-10
Can you post your code to check what is wrong ? Specially part which moves children ?
Best,
Pixamoon
