In max 2009, if I execute the following script from the editor:
x = 5
y = 3
for i = 1 to 5 do y=x^i
print y
the listener output is:
5
3
OK
3125
3125
wheres I would expect it to be just "3125".
Also, if I type "print 3*3" directly into the listener, the output is:
3
9
Is there some setting to make the listener less verbose?
if you type your scripts in the MaxScriptEditor, you only get a "3125-popup" (well, if you make a dialog for it)
the listener is especialy there to give every detail for debuggingpurposes
