Toggle Viewport Default Lighting in script
By markbola · 2009-01-20
I am trying to set the default viewport lighting to on or off and also set the 1 or 2 lights option but cannot seem to locate the correct method of doing it?
I thought it would be in the viewport class but nothing there? Does anybody know?
Cheers for your help.
markbola
cheers for the speedy reply,
Ah that was recording the ctrl + L keystroke.
The problem with this is I do not have the current state of the default lighting. I need to parse multiple files with snapshots of objects with .fx materials on them. .fx materials do not render so a viewport snapshot is done instead. My main issue is that all the files have multiple light settings so that's the reason of needing to set the default lighting with 1 light only.
dimwalker
Here is a command for turnung on/off default viewport lighting:
max default lighting toggle
found it with macroRecorder 8)
