this is good scripter source .
that is directory list box script.
when i select list box item ,i would like to know full path name .
first of all , pls make directory in c
c:temp - a - aa
- b - bb
- c - cc
- d - dd
materialib_path = "c:\\temp\\"
paths_array = #()
paths_array_list = #()
current_files = #()
bitmap_count = #()
fn matlist a b = ()
fn get_info = ()
fn build_paths path count =
count = count + 1
append paths_array path
append paths_array_list count
dir_array = GetDirectories (path + "*")
if dir_array.count > 0 then
for i = 1 to dir_array.count do
build_paths dir_array[i] count
return paths_array
fn makeoffsets li =
list = deepcopy li
for i = 1 to list.count do
ins = ""
level = 1
while level < paths_array_list[i] do
level = level + 1
ins = ins + " "
list[i] = ins + list[i]
return list
fn format_list list =
r = deepcopy list
if r.count != 0 then
for i = 1 to r.count do
l = r[i]
res = filterString l "\\"
r[i] = res[(res.count)]
return r
fn format_extensions list =
r = deepcopy list
r[i] = (filterString r[i] ".")[1]
return r
rollout materialib_rollout "111_materiaLIB v0.2" width:300 height:910
listbox lbx1 "categories:" pos:[2,24] width:160 height:55 items:#("ddd", "eee")
on materialib_rollout open do
matlist 1 materialib_rollout
paths_array = #()
build_paths materialib_path 0
lbx1.items = makeoffsets (format_list paths_array)
on lbx1 selected sel do
matlist sel materialib_rollout
paths_array = #()
ssss = #()
on lbx1 doubleClicked sel do
on lbx2 selected sel do
on lbx2 doubleClicked sel do
fn matlist sel materialib_rollout =
try
catch
fn get_file_count file =
fn get_info sel materialib_rollout =
try
catch
try
catch
try
catch
createdialog materialib_rollout style:#(#style_minimizebox, #style_titlebar, #style_sysmenu)
Comments (12)
I doubt that someone will check your code. Use
"["code"]" "["/code"]"
without the quotes and paste the cede between the tags so it can be readalbel.
You can solve your problem this way:
- create one array that contains the name of the folders(as in your example - "temp")
- create another array that contains the full paths to the folders.
Example:
pathsArr = #("temp", "matLib_01", "matLib_02")
fullPathsArr = #("c:\temp", "C:\myFolder\matLib_01","D:\matLib_02")
pathsArr will be shown in the listbox. When you select an item in the listbox somewere in the UI will be displayed the approriate path from the fullPathsArr. So:
the first item is selected - show the first element from the fullPathsArr
the 7-th item is selected - show the 7-th element from the fullPathsArr
Listbox and multilistbox can't shows tooltips, so you have to use another way to show the full path(show it in the label or in the edittext control).
@dussia
Try to respect forum rule
that folder is random
i can't array
because i will use random folder , i can;t array
folder tree is very complex
so i can't make always
example )
there is root folder - sub folder (20 pers) - sub folder (20 pers).....
i can't make array manualy
can i make automatic array about a certain folder ?
sorry my poor english
See what the FORMAT will prints in the listener and try to udenrstand what I had suggest you in my previous post.
There is no need to create the arrays manualy. The script will create them for you.
The solution:
really really really thank you , one more questio n
really thank you
can i ask question more ?
if i put file list in listbox
example)
i put list box item
with using getFiles (paths_array[sel]+"*.*")
after that
when i select item , how can i item extension ?
what item's file extention is ms or jpg or bmp .....
can you understand ?
IF you use the same code then add another editText control and when you click on an item in the listbox this will show the file type(extension) in the textbox.
really thank you again
work is good
sorry many ask , there is ask also
sorry my many ask
i tried many time , but my skill is not good
1)
current_files = getFiles (paths_array[sel]+"*.max|*.jpg")
why does that work ?
2)
about tree structre
there is directory
temp-aaa-bfff
temp-bbb-deee
temp-ccc-eeee
i would like to show 2 level tree only in listbox
example) list box showing
temp
aaa
bbb
ccc
it is tree level skill
can you understand my word ?
sorry many ask again ~
Because getFiles can have only one file extension as parameter.
You have to use:
or
or
and then separating the files by their extension.
really thank you
really really really sorry
can i ask again
list box 1 can key arrow down up
but
list box2 can;t not that
can i get reason ?
Post the code.
that solved
sorry
work is good
because of function error , that did not work
now work well
