Hi
I am having difficulty creating a swept modifier on a series of splines. The splines are generated from a text file which provides an x,y,z of each knot.
Whilst the splines come in generally correctly ( I cant tell because I cannot click on the vertex and move it etc to see the coordinate) the sweep modifier is not consistent across each spline nor follows the custom sweep object shape.
I thought this may have been a problem with the pivot but its still not working correctly.
I am also having an issue with the boolean of the left or right. I was wondering if I could get some tips on this, I am very green with Maxscript. thank you.
My code thus far is;
arr = $'Plinth*' as array
arrg = $'Grout*' as array
for i = 1 to arr.count do
if arr[i] != undefined do
delete arr[i]
delete arrg[i]
fileIn "C:\\My Projects\\Plinths.ms"
n = getOpenFileName caption:"Open Plinth File:" filename:"C:/My Projects/"
f = openfile n mode:"r"
count = 0
while not eof f do
l = readline f
data = filterstring l "|"
mySpline= splineShape name: ( uniqueName data[1])
addnewspline mySpline
tarx = data[2] as float
tary = data[3] as float
tarz = data[4] as float
tar2x = data[5] as float
tar2y = data[6] as float
tar2z = data[7] as float
addknot mySpline 1 #corner #line (point3 tarx tary tarz)
addknot mySpline 1 #corner #line (point3 tar2x tar2y tar2z)
close mySpline 1
mySpline.Name = data[1] as string
CenterPivot mySpline
beamtype = getNodeByName data[8]
for index = mySpline.modifiers.count to 1 by -1 do
if ((classOf mySplinemodifiers[index]) == Sweep) do
deleteModifier mySpline index
local sw=sweep() -- create a sweep modifier
addModifier mySpline sw -- add sweep modifier
select mySpline -- select mySplineect
mySpline.modifiers[#Sweep].CustomShape = 1
mySpline.modifiers[#Sweep].XOffset = 0
mySpline.modifiers[#Sweep].yOffset = 0
mySpline.modifiers[#Sweep].MirrorXZPlane = off
mySpline.modifiers[#Sweep].shapes[1] = beamtype.baseObject
mySpline.modifiers[#Sweep].PivotAlignment = 0
ss1 = data[9] as string
ss = substring (ss1) 1 4
--if (ss = "Left") then
-- if (ss = Righ) then mySpline.modifiers[#Sweep].MirrorXZPlane = on
mySpline.modifiers[#Sweep].Banking = off
mySpline.modifiers[#Sweep].SmoothSection= on
mySpline.modifiers[#Sweep].SmoothPath = off
the standard textfile is like this but there is many more; where its name, x knot 1, y knot1, z knot 1, x knot 2 to z knot 2, the shape STD_Plinth which looks like an L and which way it faces.
1|7270.313|-2280.269|64.913|7274.148|-2283.862|64.995|STD_Plinth|Left
Grout_ 1|7270.313|-2280.269|64.548|7274.148|-2283.862|64.63|STD_Grout|Left
2|7274.316|-2284.019|65.007|7277.151|-2286.675|65.064|STD_Plinth|Left
Grout_2|7274.316|-2284.019|64.642|7277.151|-2286.675|64.699|STD_Grout|Left
