Sweep modifier
By David Ganderup · 2015-10-02
Hi there
I am trying to ad a sweep modifier via a script (using a custom shape).
The shape are skinned (a skin modifier on top of editable spline).
When I run the script it will not take the skin modifier in ("jumps" down to the editable spline as its ref).
The thing is that it works when I manual do the process. What am I missing here?
on btn_profilDoor pressed do
selected = $
sweepMod = sweep()
select $door
addModifier $ sweepMod
sweepMod.shapes[1] = selected
sweepMod.customShape = 1
sweepMod.PivotAlignment = 8
sweepMod.AssignCSType = 2
btn_profilDoor.text = $.name
Best regards
-David
David Ganderup
Hi again pixamoon and miauu
Sorry for the confusion, i might not have made my self clear.
It is the other way around :) i need the skinmodifier to be taken into account.
Best regards
-David
David Ganderup
Hi Pixamoon
Thanx for your suggestions.
What is the .baseObject supposed to do?
The "sweepMod.CustomShapeName = selected.name" returns an error saying that it is a read only property...
-David
Baseobject is the object without any modifiers. For example if you have a mesh object with edit poly modifier and the topology of the object is changed by the edit poly modifier, the $.baseobject will gives you the o bject before the changes made by the edit poly modifier.
Search the forum for sweep modifier. I remember that Barigazy posted some snippeds for it.
Reply to miauu
pixamoon
Yes, exactly.
why .baseobject ? - because you wrote you have some skin modifier on shape, so to down step and use just a shape as custom sweep shape u need to use selected.baseobject
You can skip the line with custom shape name...
Cheers,
Pixamoon
pixamoon
Hey, Try to just use "selected.baseObject" instead of just "selected"
selected = $
sweepMod = sweep()
select $door
sweepMod.shapes[1] = selected.baseObject -- <-- add .baseObject
sweepMod.CustomShapeName = selected.name -- <-- you can add also custom shape name
Best,
Pixamoon
