surface normal to quat
By Jos Balcaen · 2012-05-19
I just can't figure this out. It works, but not perfect. (not on all faces)
 theRay = mapScreenToWorldRay mouse.pos</br>
intersectArr = (intersectRayScene theRay)</br>
pos = intersectArr[intersectArr.count][2].pos</br>
dir = (intersectArr[intersectArr.count][2].dir)</br>
z=dir</br>
tempX=[1,0,0]</br>
y=normalize (cross z -tempX)</br>
x=normalize (cross y z)</br>
tm=matrix3 x y z theRay.pos</br>
rot = tm.rotation</br>
--also tested this line</br>
--rot = (quat dir.x dir.y dir.z 1</br>
obj.pos = pos obj.rotation = rot
any help appreciated!!
Fries Boury
So what's happening in these lines is you first create a world matrix, by giving the three axes and the position.
Now, the calculation for you y axis is a bit off.
First, you should change it to y = normalize(cross z tempX)
then, second of all, the calculation for the x axis is right but what happens on the left face is that the tempX axis and the z axis are eachothers exact opposite, leaving the calculated y vector to become 0;
this can be solved by simply checking for them to be either equal or eachothers exact opposite and using (0,1,0) as tempX instead in that case
i hope this makes sense
greetz FriesB
Fries Boury
greetz FriesB
Reply to Fries Boury
Jos Balcaen
problems with sphere
Hay, thanx for reply. it works perfect at a box, but have still problems with sphere's etc..
this is my code so far
pos = &nbsp;intersectArr[intersectArr.count][2].pos
dir = &nbsp;(intersectArr[intersectArr.count][2].dir)
z=dir
tempX=[1,0,0]
print y
if y == [1,0,0] do (
   tempX = [0,0,1]
   if y == [0,1,0] do
     y=normalize (cross z tempX)
any thoughts?
Reply to Jos Balcaen
Fries Boury
try this:
z=dir
tempX=[1,0,0]
if dot z tempX == 1 do (
tempX = [0,1,0]
