Suggestions / help on Show Diffuse in Viewport Script
By 3dwannab · 2016-03-01
Hi.
I 90% of the time name my maps in the diffuse slots with 'texmatnamehere_diffuse.ext'
I've wrote a script below which collects the scene materials and then collects the mats with only '_diffuse' in the filename and then shows them map/s in each associated material (it works with submats BTW).
I just would like any suggestions or help with the following please such as:
1. Is it easy to read a bitmap for colored values and then show texmap in the viewport and possibly ignore values like in normal maps and grey-scale obviously
2. Or just general scripting knowledge to help make the code/script better.
Thanks..
theMats = for i in scenematerials collect i
theMaps = getClassInstances bitmapTexture
thePattern = "*" + "diff" + "*"
theDiffuseMaps = for i in theMaps where matchpattern i.filename pattern:thePattern ignoreCase:false == true collect i
for o in theMats do (
-- enableHardwareMaterial o theMaps[5] true
	for i = 1 to theDiffuseMaps.count do try(showHWTextureMap o theDiffuseMaps[i] true)catch()
	for i = 1 to theDiffuseMaps.count do try(showTextureMap o theDiffuseMaps[i] true)catch()
3dwannab
Thanks.
I think this script is limited to:
1. Specific render engine.
2. If say the bitmap is pluged into a Color Correct map in the diffuse slot it will not work as the bitmap is not directly in the slot.
I don't use or have VRay so don't have it installed to test.
Is no. 2 above true?
fajar
maybe its better what renderer u use....
sample for vray...
fn collectAllVrayMat selOnly:true =
	local allVrayMat= #()
	if selOnly==true then
		if selection.count!=0 do
			for i in selection where i.mat !=undefined do
				join allVrayMat (getclassinstances VRayMtl target:(i.mat))
		allVrayMat = getclassinstances VRayMtl processAllAnimatables:true processChildren:true
	makeUniqueArray allVrayMat
fn showAllBitmapTexInMat selState:true shown:true =
	allBitmapTex=#()
	allVMat = collectAllVrayMat selOnly:selState -- return allVray material
	for i in allVMat where (getProperty i #texmap_diffuse != undefined)  do
              case shown of
                      true : (showTextureMap i on)
                      false : (showTextureMap i off)
showAllBitmapTexInMat selState:true shown:true --false to not show maps
