hi all,
need some help with a current script i am writing:
all the time when it comes to subobjectlevel operations i have problems with huge performance issues. i know my scripting skills are less professional but maybe someone can point me into the right direction.
here the part of my script that makes the problems:
for c in chamferObjs do (
addModifier c (Edit_Poly name:"EditPoly_customChamfer")
clearSelection()
select c
subobjectLevel = 2
objEdges = $.modifiers["EditPoly_customChamfer"].GetNumEdges()
$.modifiers["EditPoly_customChamfer"].Select #Edge #{1..objEdges}
$.modifiers["EditPoly_customChamfer"].SetOperation #ChamferEdge
$.modifiers["EditPoly_customChamfer"].chamferEdgeAmount = chamAmount
$.modifiers["EditPoly_customChamfer"].edgeChamferSegments = chamSegs
$.modifiers["EditPoly_customChamfer"].chamferEdgeOpen = chamOpen
$.modifiers["EditPoly_customChamfer"].Commit ()
subobjectLevel = 0
) -- end for
i think the problem occurs as soon as i get into object selection mode that causes max to show what is going on and refreshing max/scene takes much longer. but without selecting each object i can not get my modifications done.
attached you find the whole script if it might help to understand what the script is used to do.
thanks in advance
-le1se
try to NOT be in the modifer tab, "activate" the "max create mode"
you might have to use a diffrent method of setting the vals and evaluating them but it will be faster.
Hi!
Check maxscript reference for "Refreshing the viewports" .
And try this:
for c in chamferObjs do with redraw off (
Also use this code to see the time
on btnChamfer pressed do
s = timestamp()
fnChamferObjs()
end = timestamp()
format "time: %\n" ((end - s)/1000.0)
) --end on
on btnChamferUndo pressed do
fnChamferObjsUndo()
) --end on
) -- end rollout
-- clearListener()
createdialog massChamfer
