String array in multilist box to object selection
By sajeel · 2016-05-04
Hi guys,
need a little help.
What i have going on in the script is as following.
1: select all the objects in the max file by select $*
2: i filter that selection by type il.e class of obj == pf source
3: store the same in a variable e.g A
4: copy the A.name to another variable B so i can use the same in multilistbox
5: create rollout and button to run other scripts.
6: Lists the selection properly
uptil here every thing is fine
7: now here's the problem the script from here onwards which was copied from
http://www.scriptspot.com/forums/3ds-max/general-scripting/multilistbox-…
heres the problem i am trying to solve multilistbox has capability to select multiple listed items using ctrl unlike listbox
what i would like to do is select multiple items in there and run scripts on them ex modifying common properties etc....
I have attached both the script file and a demo max scene to test this out :)
more details in the script below.
Thanks in advance...
[code]/*
to test please create 2-3 pf sources (rename them optional will work either ways) in the scene along with some random geo e.g sphere, torus, teapot etc.
the script will automatically filter out pfsource objects from the scenefile
What i am stuck with is in the comments below under rollout after on_Process pressed do
The Idea behind the script is when doing sims on large scale scene files with lots of PF source objects it would be nice to select
a bunch from the lest and rund scripted commands as selecting from selectbyname menu or viewport would be cumbersome and subject to mistakes
one example would be desable render or maybe recalculate caches on selected pf sources etc.
Also this is especially helpful when your pf sources or other objects are are named inconsistantly
I plan to retro fit this script to various object types and run scripted procidures on the selection
-- Define Variables
PartiGrp = #()
PartiList = #()
--slect and list pfsource
select $*
if $!= $selection then
PartiGrp[1] = $
PartiList = PartiGrp[1].name
for obj in ($ as array) do
if classof obj == PF_Source do
append PartiGrp obj
for i = 1 to PartiGrp.count do
PartiList[i] = (PartiGrp[i].name)
--UI setup
try(destroyDialog _PartiSub )catch()
rollout _PartiSub "PF source global CTRL"
Multilistbox _Multilistbox "Particle souce" items: PartiList
button _Process "Process"
on _Process pressed do
question is what if i want multiple partilce system selected so i can run scripted functions of
Code below enables me to slelect one node at a time by pressing sumbit button if i select more then one it does not work.
Beauty of multilistbox is you can ctrl + select more items from the list
_selIndex = (_Multilistbox.selection as array)[1]
-- "select fume grids"
select PartiGrp[_selIndex]
createdialog _PartiSub
[code/]
Vojtech Cada
select (for index in _Multilistbox.selection collect PartiGrp[index])
Reply to Vojtech Cada
sajeel
thanks you swordslayer,
will try this it seems i was not subscribed to the thread so didnt get notifaciton....
Thanks a ton in advance....
Regards
Sajeel
