Hi Everyone this is my script and what i cant seem to figure out is how to stop the script right after it gives the messagebox "please Redo Balls" so it doesn't play to SPH2
obj = $SPH1
if obj == undefined then messagebox "please Redo Balls"
selectmore $SPH1
obj = $SPH2
selectmore $SPH2
thanks in advance.
thanks everyone!!!!
if you use loop "for ... do...." you can use just "exit"
it can look like this:
cheers,
Pixamoon
Regarding maxscript reference file using the EXIT command must be avoided as much as possible, so you can use:
good to know :)
I checked maxscript help and found only that "exit" can be extremely slow, but didn't find any info to avoid it "as much as possible". Can you post a link to that ?
best,
Pixamoon
The exact words in maxscript reference are "Do not use return, break, exit or continue."
Here is the link.
ah, that's true
This is in chapter "How To Make It Faster" - how to make scripts faster
There is also "Disable Undo system when possible" and more...
But sometimes is good to use undo :)
Of course is good to know those functions can make scripts slower.
Thanks,
Pixamoon
