Hi I want to know if activex treeview and listview work in windows 7 and vista (32 bit)...
please if some can test this code for me it will be great...
code is in attached file these are exemples from max help thanks in advance
By B A · 2012-03-10
Comments (14)
in window 7 certification project play with very friendly the exam is very important moment in men life you can prepar from here http://www.certificationkey.com/Microsoft-Certification-Training/70-647.…
Most of the curriculum vitae include different computer related certifications. These certifications are provided after the exams that are conducted in order to stand on the merit.
642-165 || ACMP_6.1 Dumpsnow
exam sms
Many computers exam sms today have quad-core processors jogging at 2.5 to 3.2 GHz with DDR3 memory. Such bureau typically score missing you messages in the 6.9 to 7.2 foundation for CPU and sanity speed. Generally, CPU and Memory are not a adult air in outcome a Windows 7 computer fast.
Thank you Very Much...for all your great help have a good day.
register using Admin Rights
You need admin rights, or won't register.
[command prompt started w admin rights]
I've tested your scripts using your .ocx, they run fine
(I had an older version but worked too).
ActiveX stuff is not supported anymore by Microsoft, so it's a dying thing..
Eventually you should use something else, like dotnet, or else..
I only register this .ocx file to test old stuff..
dying?... :) may sound a bit speculative
Yes, its true that Microsoft end support for ActiveX but this dying process will take a whole age, as the complite migration from 32 to 64-bit is just at the beginning stage. Just for example, take a look at Excel, did someone ever plan to rewrite this application? And there is zillion staffs that no one bother to rewrite (at least for now). :)
Microsoft end the support of classic VisualBasic as well along time ago, but can call VB6 dying language? There still millions VB programmer that not plan to move to the new VB.NET
As for the man who ask here for test assistance, if he plan to make some commercial tools/apps using ActiveX, then probably will fail, but due to the opinion of the mass of people, as they belive that all AX is too dangerous, which is the myth, but the folks are controlled by myths (not by money (this is another myth)) :)
In other words, if you work for (or plan to join) company that already use/invest in OLE solutions, then nothing wrong to start lean them.
Thats a great news...Ruramuq
So In attachment this my MSCOMCTL.OCX (find in my winXP system32 directory)
please extract it first
some one can do what Ruramuq say...
for those who don't know where to input the commande (after the copy)
Click Start.
Type cmd and press enter.
then enter regsvr32 %windir%\SysWOW64\MSCOMCTL.OCX
sorry if I ask alot but I havn't acces to win 7 :( and hope that this will help someone else one day
if you download a good .ocx file, or copy from an old installation, maybe windows XP..
copy to a windows folder like syswow64, then type:
› load max2011/2012 '32bit', and if everything is fine, it should work.
So no way to use activex under win7...even 32 bit...so the only solution is using dotnet? :(
It wont work, unless MSCOMCTL.OCX file is registered manually (32bit apps).
thanks you very much...how about 32bit version?
thanks you very much really apreciated...still 32bit version any one can do this...
win7 64 bits
Thank you are you in 32bit or 64bit?
class not registered
max 2011 and 2012 win7 64
