-- Messing with \ and \\ -- [SOLVED] But another question at the bottom
Hi there, this is my first post here, and i'm a beginner in maxscript, and scripting in general.
I'm currently improving my script so it can store configuration file, and use them as variables.
I have several problem which i can't solve on my own, and, as a French young man, my english is not good enough to understand the all Maxscript Help File.
I'm Asking for help :)
So i learn there is scope things to access variables in different loop, and it's a bit hazy for me. I think It's on problem i have in my script, but first, i have a problem when edit my .ini file:
>> I must store a Network Path into my Ini File, but i just notice that the function "SetINISetting" simply ignore multiple backslash:
in my functions.ms file:
setINISetting theoutput "folders" "dossier_portes_ini" "\\\\Averty\\v\\Oskab\\scenes\\_portes\\"
setINISetting theoutput "folders" "dossier_render_ini" "\\\\Averty\\v\\Oskab\\scenes\\__RENDER\\"
in my .ini file i get:
[folders]
dossier_portes_ini=\\Averty\v\Oskab\scenes\_portes\
dossier_render_ini=\\Averty\v\Oskab\scenes\__RENDER\
But when I re-use my editvar rollout and manually type the good path,I get the good one... This is a mystery for me...
I need this function to work, because it's the defaults settings, overriding the one missing, or use as default if no modification are made.
Thanks in advance for reading me, and a thousand thanks for trying to help.
-- EDIT --
I'll try to be clear explaining this one !
First, i had only one roullout "main", opening when starting the script with everything in It, it worked well, but i like challenge and for further use, i wanted it to be editable.
So, now i have 3 files; main.ms, functions.ms and editvar.ms
main call editvar.ms by pressing a button, and when editvar close, it store all information into a temp.ini so i can access to my variables easily into main.ms
My problem is that when main start, it create a dropdownlist by parsing a folder, which can be modified by the second rollout.
since the dropdownlist is created when the first roullout is called, when i close my edit var, i don't find a way to update it (i tried "on close" but when i call it in the main script, it's gone since a long time and it does nothing)
So, for now, i close everything and launch the script again... not very handy !
Main:
http://my.jetscreenshot.com/8140/20130907-p6qh-26kb.jpg
EditVar:
http://my.jetscreenshot.com/8140/20130907-qazg-78kb.jpg
Thanks Again for helping me :)
[EDIT 2013/09/04]
Some Handy Functions I use In this script:
1) LISTNG FILES: Create a list of files To put in a DropdownList / ListBox / MultiListBox: Arguments: Directory (path to folder) / Extension (ex: "max") / Extensionlength: number of character in Extension (ex: 3) / directorylengtplus = 1 for network path (UNC) or 2 for classic path (C:\\...) [ I use one Checkbox for It] / the dropdownlist: name of the object UI.
fn listingfiles directory extension extensionlength directorylenghtplus thedropdownlist =
listeporte = getfiles (directory + "\*." + extension)
/*Creating 2 empty arrays
listetemp holds thefilename + extension
liste holds filename without the extension.*/
liste = #()
listetemp = #()
for a = 1 to listeporte.count do
directorylenght = directory.count
listetemp [a] = Substring listeporte[a] (directorylenght +directorylenghtplus) 100
counttemp = listetemp [a].count
liste [a] = Substring listetemp [a] 1 (counttemp - (extensionlength+1))
for a = 1 to liste.count do
thedropdownlist.items = append thedropdownlist.items (liste[a] as string)
2) Bdigit nb: Return a number value into a String with 4 digits:
fn bdigit nb =
tostring = nb as string
countstring = tostring.count
if countstring == 4 then result = tostring
if countstring == 3 then result = ("0" + tostring)
if countstring == 2 then result = ("00" + tostring)
if countstring == 1 then result = ("000" + tostring)
return (result)
Comments (25)
And.. one More Problem !
Thanks for your good advises, i didn't use struct for now, but it's look very nice, and i surely use them into my next script :)
I've got a little problem, which i don't understand, maybe because it's 5am here, and i don't manage to find a solution.
It's quite funny because it's working in a 2 lines script but not in the real one.
When i was working on the script, i made my path point to my desktop in an absolute path, and the script worked well. But when i made the mzp, and made the include point to function.ms by using userscript...
when i try this:
the listener is parsing the entire file, so i assume he found it, but in my main script it crashed.
ps: it's working when I enter the all path in absolute of course, but it's not the point of creating a mzp-file to deploy on several computers.
You can't use line
. Max not recognize this. Now is the time to place all your fn's in struct. And your problem will disappear
-Loosing It-
Tell me if i'm wrong, but when i use Struct to organize my functions.ms file, i will always have to include the function.ms file into my main.ms right?
I'm looking all over the web to find examples, but i found contradictory information. example: "don"t use include but file fileIn" Or "Omg you're using Filein, just use include !"
I'm confused
Here: http://neiltech.wordpress.com/2012/11/16/how-to-create-a-class-in-maxscr…
>> I understand the goal of using Struct, because we have 2 functions in the struct MyClass , executed by calling one Struct "MyClass"
But in my case, functions.ms is just a bunch of functions, and using Struct could organize them by type (Ini things / main script), but i don't understand the point.
Here's my functions:
No no. Place all fn's from "function.ms" inside struct. But struct neet to be placed in main.ms. Forget about fileIn and include fn's.
Can't find editText.text
Hi there, i'm stuck again.
I put all my function into my main script, into one sturct called "Myfunctions"
I initialize it before i declare my 2 rollouts.
The functions used by the main works just fine, but inside the settings rollout, the functions using the ".text" parameters of the edittext UI is not found by maxscript, and so i can't load or save new Ini...
I give you a piece of my code as exemple, into EDITVAR ROLLOUT (L103),I have several edittext exmple: "In1"
Into my save and load ini functions (L6 & L15) i use the .text parameters to get or assign a stringvalue, but max can"t find the .text parameters now. Is this a scope problem? I thought my functions are available anywhere in my code by using a global initialization of the struct...
I tried to get or assign a value directly from the rollout, not calling a pre-build function, it worked.
So my question is how can i do to make the.text parameters available into my function?
Thanks in advance,
Florent
This is the corrected code. I did not tested, but you can.
Read my "upercase" comments.
Also look how I initialized struct.
struct MyFunctionsStruct
inidir = (getdir #userscripts + "\\Tool"),
tempini = (inidir + "\\_temp.ini"),
toolini = (inidir + "\\Tool.ini"),
fn saveini thedir theoutputfile ctrl = -- ADD "CTRL" ARGUMENT POR YOUR ROLLOUT CONTROL EI.EDITTEXT
GetINISetting thedir "SectionName" "KeyName" -- WHY THIS LINE IS NOT STORED IN SOME VARIABLE
-- create and set new ini file
setINISetting theoutputfile "Usefull_Frames" "in1_ini" ctrl.text
--Load Ini
fn loadini thedir theimputfile ctrl = (ctrl.text = getINISetting theimputfile "Usefull_Frames" "in1_ini"),
-- create Tool.ini
fn createToolini =
local inidir = getdir #userscripts + "\\Tool"
local nameini = "Tool.ini"
local theoutput = inidir + "\\" + nameini
GetINISetting inidir "SectionName" "KeyName" -- WHY THIS LINE IS NOT STORED IN SOME VARIABLE
-- create and set Tool ini file
setINISetting theoutput "Usefull_Frames" "in1_ini" "1"
-- Clear All
fn cleareditvar ctrl = (ctrl.text = ""),
--Load tempini
-- Load a parameter into the main funciton, get default if no one found
fn loadtempini theparam theparamcategory =
local theparamini = theparam + "_ini"
local testtemp = getINISetting tempini theparamcategory theparamini
theparam = (if testtemp.count == 0 then (getINISetting Toolini theparamcategory theparamini) else testtemp)
-- Lister des fichiers dans un dossier et les ajouter à une dropdownlist
--directorylenghtplus = 1 si network path, 2 sinon
fn listingfiles directory extension extensionlength directorylenghtplus thedropdownlist = (),
-- bdigit d'un nombre: convertir un nombre en paddin XXXX (exemple: 1 -> 0001) return: string
fn bdigit nb = (),
fn getportename prox = (),
--Assign le material d'"obj_shader_name" au layers correspondant a findthelayers
fn assignmattolayer obj_shader_name findthelayers =()
global MyFn = MyFunctionsStruct()
--END FUNCTIONS
try(DestroyDialog ::main)catch()
if (doesFileExist MyFn.tempini) == true then () else ()
-- EDITVAR ROLLOUT
rollout editvar "Tool Settings " width:250 height:550
-- MAIN ROLLOUT
rollout main "Tool - Create" width:250 height:200
createDialog main 250 125
I think i'm getting in but
Hi there, sorry for the late response, i didn't have time too look at the code yesterday. Youre code is working great but in my case (i didn't tell you all so you were unable to know, but i have about 70 Edittext or check box to load, save or clear.
At the first time, i wanted to save, load or clear all of them by calling one short function for each action into my rollouts
It work when adding the ctrl parameters, but i have to call the function 70 times. Although, i have different type, check-boxes ant EditText, so i cant use the same syntax when i want to get the.text value or the TriState. It's the same problem when i load or save, i have different group in the Ini, different types of values, etc.
I Give you an example with the clear function:
>>With the struct and calling 70 times:
I don't which solution is the more efficient, because in 3 case (loading / saving and clear) each time i want to do one action i call one function In struct 70 times
In that case, i can't call the fucntion insode another rollout thant the one where the fucntion is declare... not handy, but i can cear all of my parameters in one line into mu editvar Roullout:
I tried several thing (don't forget i'm starting, i'm sure it will look strange for you)
>> print the edittext directly and save it to a .ini: : i get "EditTextControl:"
>> but i heard that i have to avoid the execute function for "converting" a string to get the variable with the same name:
exemple:
It can loop for X Variable, but it's very slow, and dirty... and i have still other Edittext who can"t enter in this loop...
I tried a few things, but except crashing the script it's not helpfull.
Can i declare Struct int Struct ? so i could store all my parameters and execute them 70 time by calling another struct parameter ?
exemple: Struct theparams (in1, in2 ... in40,checkbox1...)
So i can call cleareditvar for each params in the same time...
I'm Trying, I didn't count the Google researches about scripting or optimize in the way I want, there's no many article about struct...
Thanks For your time, at worst i can copy/paste the all dirty code into my script, i know it will work, but i'll not be satisfied about it.
I not have time right now to read your post but see this example
"main" is your rollout and you can simply loop and affect only edittex controls like this
for c in main.controls where classof c == EditTextControl do
-- to collect all text
textArr = #()
append textArr c.text
-- to remove text
c.text = ""
-- to collect all names of edittext controls
namesArr = #()
append namesArr c.controls[1].caption
--etc.
You can test with this example
try this in the listener
textArr = #()
format "textArr >> %\n" textArr
-- to remove text
c.text = ""
namesArr = #()
format "namesArr >> %\n" namesArr
--etc.
Is this easy or not
;)try(destroyDialog ::main)catch()
struct mainDataStruct
cbDataArr = #(),
txtDataArr = #(),
fn clearAllData roll =
for c in roll.controls do
case classof c of
(CheckBoxControl): c.tristate = 0
(EditTextControl): c.text = ""
fn saveAllData roll =
free this.cbDataArr ; free this.txtDataArr
case classof c of
(CheckBoxControl): (append this.cbDataArr c.tristate)
(EditTextControl): (append this.txtDataArr c.text)
fn restoreAllData roll =
local cnt1 = 1, cnt2 = 1
case classof c of
(CheckBoxControl): (if this.cbDataArr != #() do (c.tristate = this.cbDataArr[cnt1] ; cnt1 += 1))
(EditTextControl): (if this.txtDataArr != #() do (c.text = this.txtDataArr[cnt2] ; cnt2 += 1))
global RUN = mainDataStruct()
rollout main "• • •"
local randomFiles = for i = 1 to 10 collect (dotNetClass "System.IO.Path").GetRandomFileName()
checkbox cb1 "cb1" width:50 tristate:(random 0 1) across:2
edittext et1 "eText1" width:120 text:randomFiles[1]
checkbox cb2 "cb2" width:50 tristate:(random 0 1) across:2
edittext et2 "eText2" width:120 text:randomFiles[2]
checkbox cb3 "cb3" width:50 tristate:(random 0 1) across:2
edittext et3 "eText3" width:120 text:randomFiles[3]
checkbox cb4 "cb4" width:50 tristate:(random 0 1) across:2
edittext et4 "eText4" width:120 text:randomFiles[4]
checkbox cb5 "cb5" width:50 tristate:(random 0 1) across:2
edittext et5 "eText5" width:120 text:randomFiles[5]
checkbox cb6 "cb6" width:50 tristate:(random 0 1) across:2
edittext et6 "eText6" width:120 text:randomFiles[6]
checkbox cb7 "cb7" width:50 tristate:(random 0 1) across:2
edittext et7 "eText7" width:120 text:randomFiles[7]
checkbox cb8 "cb8" width:50 tristate:(random 0 1) across:2
edittext et8 "eText8" width:120 text:randomFiles[8]
checkbox cb9 "cb9" width:50 tristate:(random 0 1) across:2
edittext et9 "eText9" width:120 text:randomFiles[9]
checkbox cb10 "cb10" width:50 tristate:(random 0 1) across:2
edittext et10 "eText10" width:120 text:randomFiles[10]
button btn1 "SaveData" across:3 align:#left
button btn2 "ClearData" align:#left
button btn3 "RestoreData" align:#left
on btn1 pressed do RUN.saveAllData main
on btn2 pressed do RUN.clearAllData main
on btn3 pressed do RUN.restoreAllData main
on main close do RUN = undefined
createDialog main 250 250 10 110 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
It's A Succes !!
Many Thanks barigazy, I just modify a little your code to set and get ini settings, It's Working !!
I have to make little adjustments to my main code to log my print information into a external file if asked by user to end this.
This make me won a huge amount of time at work. I'm already thinking about another script to improve my pipeline again.
The script is too specific to be posted and shared, but the functions could be used by others.
I will update the first post to share a few of them.
Thanks Again You Rock Man !
My pleasure. :)
One more thing I forget to tell you abut struct.
You can load or create "ini" settings when strut is created using "on create" event.
Look at the code of this script where I write and load UI settings from XML file.
This is a bit advanced but U can use *.ini file in the same way.
http://www.scriptspot.com/3ds-max/scripts/scriptrun
Organizing Is a good thing
It's working... for now.
I just re-organize my script, declare the 2 rollout in the same file, and simply close and open the main roullout when editvar close, the variable "folder" change and the dropdownlist is updated. It's dirty, close and open to update but it work...
I'll post handy functions after a few more tests :)
Sometime is better to pack all your stuff in one file for sure, u can use "struct" to organize your fn's and variables for easy acces.
I Keep your source code aside for my next project. I hope i could share this one after use. Your Tips will be very handy then :). I must Learn DotNet classes.
I really appreciate your help Barigazy. I Have no good resources to learn maxscript on my own, and nobody's making fun with maxscript here... :) Thanks Again !
I know I have to Put functions into my forst post, I will, i promise, but now i have the script i have to use it since it's ready to produce images... That why i didn't reply sooner.
Shorter version of your 2nd fn
fn bdigit nb = formattedPrint nb format:".4d"
Also 1st fn can be optimized but I not understand french :)
Thanks again for the optimization ! :D I know that i have to avoid the return function, but i didn't know how to do it your way :D
I translate the text in the first function :p I have several more to add but i don't now if they can be usefull for others.
Now about 1st fn optimisation
I next example I will use .net method to collect all files in specified directory by given extension and extract only file name without extension (optional)
--arguments info:
--directory --> search directory
--extArr -- > extensions array . example #("*.jpg", "*.zip", "*.txt") etc.
--opt --> Specifies whether to search the current directory, or the current directory and all subdirectories.
-- use #top_folder to search only the current directory
-- or #all_folders Includes the current directory and all its subdirectories in a search operation
--&fileNames --> this is the optional argument. Can be supplied with predefind arr or unsupplied
fn collectFilesByExtensions directory: extArr: opt: &fileNames: =
local listeporte = #()
local sioDir = dotNetClass "System.IO.Directory"
local sioSOpt = dotNetClass "System.IO.SearchOption"
local filtOpt = case opt of
(#top_folder): sioSOpt.TopDirectoryOnly
(#all_folders): sioSOpt.AllDirectories
for ext in extArr do join listeporte (sioDir.GetFiles directory ext filtOpt)
if fileNames != unsupplied and isKindOf fileNames Array do
local sioPath = dotNetClass "System.IO.Path"
for p in listeporte do append fileNames (sioPath.GetFileNameWithoutExtension p)
listeporte
How to use it?
Let say you want to collect all mxs files inside max root directory
Now if you want also to collect file names then you can do next
-- define a empty array which will hold file names only
fileNamesArray = #()
-- add this array in last argument of function
mxs = collectFilesByExtensions directory:(getDir #maxroot) extArr:#("*.ms", "*.mse", "*.mcr") opt:#all_folders &fileNames:fileNamesArray
-- by runing this fn you will get two arrays: all full file paths and file names
-- to see result print in the listener next two lines
print mxs --full file paths
print fileNamesArray --file names
And at the end just fill your dropdown list
I hope this will help
... I'm ashamed to not know that, thanks a lot, that solve one of my problems !
Then post 2nd problem :)
Are you try using "@" sign before path string
setINISetting theoutput "folders" "dossier_portes_ini" @"\\\\Averty\\v\\Oskab\\scenes\\_portes\\"
