small modification needed with this anton script for object export
By kutty · 2009-08-17
hi,, i would like to have this script to modification,, little bit,, like while the export should make the object export with the file name instead of the object name in the max, also if possible,, i want to export 6 object defined names which i want to export to specified folder, which should include the path in the script to define,, can anybody help.,,
i will specify the 6 objects with names and the output path in the script,, and it should just export the objects with the file name not with the object name
--this script is made by Anton Berg at os3d.se
--anton[at]os3d.se
rollout ExportObj "Export as separate files" width:232 height:107
global theClasses
global outPath
local debug = true
edittext edt1 "filename" pos:[8,83] width:152 height:16 readOnly:false
button btn1 "Export" pos:[168,59] width:56 height:40
checkbox chk1 "Prefix of the file:" pos:[9,62] width:120 height:16 checked:true toolTip:"if this is checked then the prefix text will be used to name the file"
dropdownList ddl2 "FileType" pos:[9,6] width:152 height:40
checkbox chk2 "Debug" pos:[168,29] width:56 height:16 checked:true tooltip:"This will show error messages"
fn NewfileName inputPath objName ischecked nr= (
if ischecked == true then
--set the filename to this prefix
np = inputPath + "\\" + objName + "_"+ nr as string --+".obj"
if debug then print np
--set the filename to the object filename
np = inputPath + "\\" + objName --e+ ".obj"
return np
on ExportObj open do
theClasses = exporterPlugin.classes
theClassesNames = #()
for exptyp in theClasses do
append theClassesNames (exptyp as string)
ddl2.items = theClassesNames
on btn1 pressed do
if outPath == undefined then outPath = ""
outPath = getSavePath initialDir:outpath
if outPath != undefined then
selArray = selection as array
sceneObjs =#()
for item in selArray do
try (explodeGroup item)
catch()
if (isKindOf item GeometryClass) then append sceneObjs item
for i = 1 to sceneObjs.count do
oname = (if chk1.state then edt1.text else sceneObjs[i].name)
if i == 1 then
select sceneObjs[i]
newName = NewfileName outPath oname chk1.state i
result = (exportFile newName using:(theClasses[ddl2.selection]) selectedOnly: true)
if result != true then (
if chk2.state == true then (messageBox "OS3D debug INFO:\nYou have a selected a filformat that doesn´t except the selected only state..")
result = (exportFile newName using:(theClasses[ddl2.selection]) selectedOnly: false)
if i > 1 then
select sceneObjs[i]
result = (exportFile newName #noPrompt using:(theClasses[ddl2.selection]) selectedOnly: true)
--messageBox "You have a selected a filformat that doesn´t except the selected only state.."
select sceneObjs
messagebox "No output path selected"
on chk1 changed theState do
if theState then edt1.readOnly = false else edt1.readOnly = true
createdialog ExportObj
Cananybody help this out,,, ???
Anton Berg
I just did some modifications to this script today for another user but unfortunally it is not a solution to what you want.
Could you just describe a bit more what you want? Preferebly via examples.
Do you want all outputfiles to have the same name? But end up in a unique folder or?
just give som examples of:
1. what would the input look like. My guess is - theMaxFileName
2. what do you mean by: i want to export 6 object defined names which i want to export to specified folder
do you mean that you have 6object in your scene that you want to export all of them to a separate folder but with the same filename?
/object1/maxfileName.obj
/object2/maxfileName.obj
/object3/maxfileName.obj
/object4/maxfileName.obj
3. What fileformat do you want to export to?
OgmaSoul3D
Anton Berg
anton[at]os3d.se
