Hi all masters, i need some help here. I need simplify code script from my script, its work fine but i think it can be simplified.
try destroyDialog Rtest catch()
rollout Rtest "Test-Rollout"
button bt1 "Load_Material"
button bt2 "Apply"
edittext 'Fdir' "" width:130 height:20 enabled:false
on bt1 pressed do
local curpath = Fdir.text
local newPath = getSavePath initialDir:(curpath) caption:"Select the path where your Images are located"
if newPath != undefined then
Fdir.enabled = true
Fdir.text = newpath
--HERE START A LARGE CODE--
meditMaterials[1] = Multimaterial ()--Apply MultiMaterial in the first slot of Material Editor
meditMaterials[1].materialList[1].diffuseMap = Bitmaptexture fileName: (Fdir.text +"\1.png") -- Load image in diffuse slot map
meditMaterials[1].materialList[1].opacityMap = Bitmaptexture fileName: (Fdir.text +"\1.png") --Load the same image in opacity slot map
meditMaterials[1].materialList[1].opacityMap.monoOutput = 1 -- Active alpha ouput for mask diffuse map
meditMaterials[1].materialList[1].showInViewport = on --Show material in viewport
--- HERE MY QUESTION,: I HAVE TO REPEAT THIS STEP FOR ALL MATERIALS ?, SOME SUGGESTION TO SIMPLIFY THIS?--
meditMaterials[1].materialList[2].diffuseMap = Bitmaptexture fileName: (Fdir.text +"\2.jpg")
meditMaterials[1].materialList[3].diffuseMap = Bitmaptexture fileName: (Fdir.text +"\3.jpg")
on bt2 pressed do
for obj in selection do if obj.material == undefined then
obj.material = meditMaterials[1] -- Apply Material in selection objects
messagebox "Ready Material"
createDialog Rtest
thanks for your help.
try destroyDialog ::Rtest catch()
local sioDir = dotNetClass "System.IO.Directory"
local sioSOpt = (dotNetClass "System.IO.SearchOption").AllDirectories
button bt2 "Apply"
edittext Fdir "" width:130 height:20 enabled:false
on bt1 pressed do
local curpath = if sioDir.exists Fdir.text then Fdir.text else ""
local allFiles = sioDir.GetFiles newPath "*.*" sioSOpt
if allFiles.count > 0 do
local extensions = #(".jpeg",".jpg",".png"), cnt = 0
node = for f in allFiles where (ext = findItem extensions (tolower (getfilenametype f))) > 0 collect
mtl = if ext != 3 then standard name:(getFilenameFile f) diffusemap:(Bitmaptex fileName:f) else
map = datapair diff:(Bitmaptex fileName:f) trans:(Bitmaptex fileName:f monoOutput:1)
standard name:(getFilenameFile f) diffusemap:(map.diff) opacitymap:(map.trans)
mtl.showInViewport = on ; mtl
meditMaterials[activeMeditSlot] = Multimaterial materialList:node
on bt2 pressed do if selection.count > 0 do selection.material = meditMaterials[activeMeditSlot]
createDialog Rtest
