shift+toolbar button click question
By harumscarum · 2014-11-22
hello
i have toolbar button which toggle Vertex Ticks on selected objects. how could i add shift+button click action to OFF vertex ticks on all selected objects instead toggle it
macroScript vertTicksToggle category:"_harumscarum" buttonText:"vtToggle" tooltip:"Vertex TicksToggle"
fn filt obj = isKindOf obj GeometryClass or isKindOf obj shape
if selection.count != 0 do
for o in selection where filt o do o.vertexticks = not o.vertexticks
You can't do it with Shift button, but you can do it with Alt button. Check maxscript help file for:
on altExecute
But your script should works as toggle - run it once to show verts ticks, run it again to turn vertex ticks off. I have the script that I use to turn on/off vertex ticks.
	on isEnabled return selection.count != 0
	on execute do
		try
			for o in selection do o.vertexTicks = not o.vertexTicks
		)catch()
No need for altExecute or any other action.
Reply to miauu
hummus
Does altExecute work with ToolBar buttons?
I checked the altExecute documentation and it mentions working on Quadmenus but doesn't specify toolbar buttons, and when I tried it on a toolbar button I got no affect.
Is it possible to use Alt+Click on toolbar buttons, and if so - can you show an example of that working?
Thanks.
