send variable between 2 scripts
By JeremyA · 2018-05-24
Hi
I am trying to send a variable from one script to another.
When I click on script "test02", I activate "test03". I want "test03" to send the variables to "test02" to display BatchNumberLoading, BatchNumberTotal and Progressbar. It is to follow the export.
I reduced my code to focus on my problem
I know that the code below is not well placed,I do not know where to place it
BatchNumberTotal.text= theFilesNumber as string
BatchNumberLoading.text= theFilesCurrent as string
But the mark value received is "undefined"
Do you have an idea? Thx
Test02.ms
-- 	BatchNumberTotal.text = theFiles as string
-- 	BatchNumberLoading.text = f as string
	PathBatchMAX = "C:\Users\PC_new\Documents\Perso\Script\Test03.ms"
	rollout test02 "test02"
		group ".max" (
		button btn_SaveMaxBatch "Batch copy" align:#right toolTip:"Current version useless and 3 previous versions!"
		label BatchNumberLoading "No Value" align:#right across:3
		label BatchNumberSeparate "/" align:#center width:10
		label BatchNumberTotal "No Value" align:#left
		Progressbar loading color: [169,38,158]  height:20 align:#right
		on btn_SaveMaxBatch pressed do
				fileIn PathBatchMAX
	) -- end rollout
	createDialog test02 220 120
Test03.ms
 Clearlistener()
	thePath = getSavePath()--get a path dialog to specify the path
	if thePath != undefined do--if the user did not cancel
		theFiles = getFiles (thePath+"\\*.max") --collect all max files in the dir.
		theFilesNumber=theFiles.count
		theFilesCurrent=theFilesNumber-theFilesNumber
		print (theFilesCurrent as string + "/" + theFilesNumber as string)
		for f in theFiles do-- go through all of them
			loadMaxFile f--load the next file
	-- MAKE SOME SCRIPTED CHANGES TO THE SCENE HERE...
		-- SAVE MAX START
-- 		temp_node = box()
-- 		temp_node.name = substituteString maxfilename ".max" ""
-- 		fileName = temp_node.name
-- 		delete temp_node
-- 		saveMaxFile (MaxFilePath+fileName+"_new.max") useNewFile:false
-- 		print (fileName)
		-- SAVE MAX END
		-- COUNT StART
		theFilesCurrent=theFilesCurrent +1
		fileNameCurrent=substituteString f thePath ""
		-- COUNT END
		print (fileNameCurrent as string + " SAVE")
		)--end f loop
	  resetMaxFile #noPrompt --at the end, you can reset
-- 	  BatchNumberTotal=theFiles
	)--end if
JeremyA
Thank you for your answer. It's good!
I added Progressbar and scene name loading.
Thx again ;)
	global test02
		group ".max" (
		Progressbar loadingbar color: [169,38,158]  height:20 align:#right
		label LoadingCurrentName "No Value" align:#center
				fileIn PathBatchMAX
	) -- end rollout
		print (theFilesCurrentpercent as string + "%")
		::test02.LoadingCurrentName.text= fileNameCurrent as string
		-- COUNT StART
		theFilesCurrentpercent=theFilesCurrent*100/theFilesNumber
		-- COUNT END
		::test02.BatchNumberTotal.text= theFilesNumber as string
		::test02.BatchNumberLoading.text= theFilesCurrent as string
		::test02.loadingbar.value= theFilesCurrentpercent as integer
		)--end f loop
	)--end if
Test this:
	global test02
		group ".max" (
			fileIn PathBatchMAX
	) -- end rollout
Clearlistener()
		-- SAVE MAX START
-- 		delete temp_node
-- 		print (fileName)
		-- SAVE MAX END
		-- COUNT StART
		-- COUNT END
		)--end f loop
	)--end if
Or make the theFilesNumber and theFilesCurrent global so both script to have access to them.
