I have a problem in one script and I'm need a help please.
I am selecting a series of lights, some VRayLight and others do not. To turn off some lights use $lights.enabled = off, but some lights use the command $lights.on = off as an example are the photometrics and Vraylights ... When I use $lights.on = off gives the following error "- Unknown property:" on "in $ VRaySun: @ Sun_Cam_portaria [149.746979, -227.845520,0.000000]" How do we work? There is a class for vraylights?
thanks
Kim
Just create rollout with two buttons ("On" and "Off")
and then you can toggle lights on-off.
Cheers!
Very very good.
worked very well
perfect and clean
Just put the basic script I'm doing.
Thanks...
And this is the shorter version
Tested and works fine.
Also work on the Daylight System
Now supports and FinalRender Lights
fn TurnTheLights state: =
if selection.count != 0 do
local lightTypes1 = #("Light", "mr Area Omni", "mr Area Spot", "VRayIES", "VRayAmbientLight", "VRaySun", "fRParticleLight")
local lightTypes2 = #("Skylight", "Photometric Light", "mr Sky Portal", "VRayLight", "RectLight", "fRDome", "CylinderLight", "fRParticleLight")
for lgh in selection where isKindof lgh Light do
if finditem lightTypes1 (getClassName lgh) != 0 then (lgh.enabled = state)
else if finditem lightTypes2 (getClassName lgh) != 0 do (lgh.on = state)
--Now you can set state on or off
TurnTheLights state:off --turnoff lights
--TurnTheLights state:on --turnon lights
good
Hey Man very thanks...
I will test and send feedback..
I added twice "VRayAmbientLight".
I corrected the previous code.Copy again and try.
TurnTheLights (ON or OFF)
You decide which state you need (on or off)
Supports all: VrayLights, mrLights, Standard and Photometric
Use this function.
fn TurnTheLights state:off =
case getClassName lgh of (
("Light"): lgh.enabled = state
("Skylight"): lgh.on = state
("Photometric Light"): lgh.on = state
("mr Sky Portal"): lgh.on = state
("mr Area Omni"): lgh.enabled = state
("mr Area Spot"): lgh.enabled = state
("VRayLight"): lgh.on = state
("VRayIES"): lgh.enabled = state
("VRayAmbientLight"): lgh.enabled = state
("VRaySun"): lgh.enabled = state
