Is there any solution to select vertical faces of the Editable Mesh object?
Select only vertical faces of the EditableMesh object
By harumscarum · 2023-06-05
ChatGPT did the job, however it do not know how to select faces, may only delete it
and it is slow
The code you have will delete bottom faces of a box primitive converted to Editable Mesh.
it might be faster to use abs to make just a single value comparison
like that:
