Select objects by prefix and group them using group name same as prefix
By zwrtron · 2015-07-23
Hello everyone, I started with maxscript few days ago and I'm stuck in this.
I have multiple objects in scene, like: (objectnames)
color_black
color_red
color_blue
bar_1
bar_2
plane001
plane002
and I would like to ask how do I use "select" function to select them.
I've used this to select one of them.
select ($color_black)
How can I select all object in scene starting with "color" "bar" "plane"?
and make group with names "color" "bar" and "plane"
Thanks for any help.
Comments (9)
pixamoon
I think you can use just:
select $color*
or
select $bar*
etc :)
Reply to pixamoon
zwrtron
Thank you!
Thank you very much! It working well.
Could you please help me?
I have script to select and group these objects but I have an issue with object names inside the group.
Example:
I have objects:
Plane001
Plane002
Plane003
And I have following script:
clearSelection()
select $plane*
actionMan.executeAction 0 "40140"
$.name ="plane"
clearSelection()
The problem is, that it renames also objects inside the group.
So the group called 'plane' contains objects all named 'plane' instead of original names (plane001, plane002 ...);
I've also tried and doesnt help.
clearSelection()
select $body*
clearSelection()
select $Group001
$.name ="body"
clearSelection()
Reply to zwrtron
pixamoon
try this one:
a = $plane*
g = group a
g.name = "plane"
or
a = $plane*
g = group a name:"plane"
or one line:
g = group ($plane*) name:"plane"
Reply to zwrtron
pixamoon
no prob :) got one more idea, if you want to do it for multiple names at once:
names = #("box","plane","sphere","teapot")
for a in names do execute("g = group $"+a+"* name:\""+a+"\"")
Cheers
Pixamonn
Reply to pixamoon
mani
thanks
hi.
i rummade maxscript help for about 3 weeks and it was just dumb. i found the answer here. thanks.
Reply to pixamoon
Maryam AlBalushi
select all groups
I am trying to write a line of a script which basically tells 3ds max to select all groups. All I am able to do in max script listener is to see the name of objects selected in one line. If you can write that line for me, I can integrate it with some other lines to make a script that aims to export each individual group to a separate file. I really need that to breakdown the weight of a massive interior project which will, hopefully, reduce the render time after being combined by using the method of "xref scene".
Code
Hello, this should work but i'm not sure this is the simplest way to do it, but it works for me.
groupArr = #()
for i in helpers do
	if (isGroupHead i) == true then
		append groupArr i
select groupArr
