Select object less than x size
By M0nkey · 2010-08-17
Does anyone know of a script that will select objects smaller than x volume or size?
M0nkey
Thank you Anubis!
Love your work
-- modified version of the
-- modified version of the example function from the MxsHelp:
fn CalculateVolume obj =
	local Volume= 0.0
	local Center= [0.0, 0.0, 0.0]
	local theMesh = snapshotasmesh obj
	local numFaces = theMesh.numfaces
	for i = 1 to numFaces do
		local Face= getFace theMesh i
		local vert2 = getVert theMesh Face.z
		local vert1 = getVert theMesh Face.y
		local vert0 = getVert theMesh Face.x
		local dV = Dot (Cross (vert1 - vert0) (vert2 - vert0)) vert0
		Volume+= dV
		Center+= (vert0 + vert1 + vert2) * dV
	delete theMesh
	Volume /= 6
	Volume
volLimit = 33.0 -- set desired volume limit
-- end select...
select (for obj in geometry where CalculateVolume obj <= volLimit collect obj)
