Select longest edges in unwrap
By turbinea · 2015-06-18
Hi, is there any chance you could help me with script problem?
I have long strip of polygons of varying length, kinda like long ladder, and i need to select 2 longest edges of side rail, not the rung. While i need to get selection in unwrap editor, it needs to be based on edit poly edge's length not UV edges.
Basically i have long list of these ladder like meshes and need to match it to certain places in UV space. So, i plan to select longest_edge[1], run loop and slide it to correct position, then repeat the process with longest_edge[2]
I can do looping and moving, just can't get the selection part.
Can anyone help me with this?
T.
tahir
GREAT SCRIPT! is it possible to make same with simultionesly selected group of elements ...
Reply to tahir
Can you explain how exactly the script should works?
This will select the longest edge of selected edges of an Editable Poly object. Select some edges and run the script. It will select the longest edge from the selected edges. Then you have to select the coresponging UV edge and continue with the loop and slice.
	curO = selection[1]
	if classOf curO == Editable_Poly then
		if subobjectlevel == 2 do
			selEdgesBA = polyop.getEdgeSelection curO
			if selEdgesBA.numberset != 0 then
				longestEdge = undefined
				minLength = 0
				for ed in selEdgesBA do
					edgeVertsArr = polyop.getEdgeVerts curO ed
					edgeLength = distance (polyop.getVert curO edgeVertsArr[1]) (polyop.getVert curO edgeVertsArr[2])
					if edgeLength > minLength do
						minLength = edgeLength
						longestEdge = ed
				polyop.SetEdgeSelection curO longestEdge
				messagebox "Select some edges" title:"Empty Selection"
		messagebox "Select Editable Poly object" title:"Wrong Selection"
