select folder - write variable - show in textfield - beginner needs help
By dallchris · 2013-12-19
Hi everybody.
i'm new to maxscript and i'm trying just a easy thing(not easy for me but for the professionals here yes) I want to create a rollout with a button "browse", where I can select a folder. for example c:\user\desktop\maps\. This path should be stored as a variable (and need it for an later action in the script) and should be shown in my edittext box and the user should be able to select and copy the path. for now it's half working with the attached script. But if I press a second time on the button "Browse" I can select another folder for example d:\materials the script changes the variable (for testing I used the print function) but did NOT show it in my edittext?Is there a kind of autoupdate function?
Is there anyone out there how can help me ???
thanks a lot in advanced and greetings chris
    rollout xx "Maps Path" width:800 height:496
   button btn_browse "Browse" pos: [124,10] width:60 height:16
    label choose "select maps path " pos:[8,10] width:112 height:16
   on btn_browse pressed do
     dir = getSavePath caption:"Select Folder" initialDir:#images
       print dir
          edittext theedittextt "Path" text:dir
rof=newrolloutfloater "Test"800 600
addRollout xx rof rolledUp:false
dallchris
perfect... solved
thanks a lot this works very fine :) this was exactly I was looking for :)
now I can finish my script and start my xmas holiday :)
merry xmas to all
Raymond Homme Ingebretsen
I am not sure that i understand, but is it something like this you want:
	try(destroyDialog ::rol_Browse_SavePathINI)catch()
	rollout rol_Browse_SavePathINI "Browser"
		local foldersPathIni = "C:\\Temp\\FolderSettingsIni.ini" -- Change this to whatever you want the INI file to be stored.
		group ""
			button btn_1_Open "Open File" pos: [114,16] height:18
			button btn_browse1 "Browse" pos: [190,16] width:60 height:18 tooltip:"Set Path"
			label lbl_choose "Select maps path:" pos:[8,16] width:90 height:18
			label label_item1 "..." pos:[8,40] width:290
		-- Functions
		function SelectFolder btn =
			dir = getSavePath caption:"Select folder" initialDir:(getIniSetting foldersPathIni btn "folder_path")
			if dir != undefined do
				setIniSetting foldersPathIni btn "folder_path" dir
		    label_item1.text = (getIniSetting foldersPathIni "btn_browse1" "folder_path")
		function OPENFoldersAndFiles dir =
			try (
			f = getOpenFileName caption:"Open File..." \
			filename:(dir + "\\") \
			types:"Max(*.max)|*.max|All|*.*|"
			files = getFiles f
			for f in files do (loadMAXFile f)
			) catch()
				messagebox "Please select File"
		-- Button Pressed Stuff
		on btn_browse1 pressed do
			SelectFolder "btn_browse1"
		on btn_1_Open pressed do
			OPENFoldersAndFiles ((getIniSetting foldersPathIni "btn_browse1" "folder_path"))
		on rol_Browse_SavePathINI open do
createDialog rol_Browse_SavePathINI width:260 height:70
