Select Face Array
By Willian Kim · 2012-06-05
I need a help in faces...
I'm trying to collect some faces, some faces have an array but I can not load the array in setSelection ...
Thanks in advanced
	prov = $.selectedFaces as integer
-- Unable to convert: #faces(181, 234, 347 : $Editable_Poly:Plane003 @ [32.705963,272.583252,0.000000]) to type: Integer
prov
$.EditablePoly.SetSelection #Face #{prov}
Comments (21)
Here we go
with redraw off
max create mode
plane1 = $Plane001
plane1Mod = plane1.modifiers[#Vol__Select]
modNode = plane1Mod.node
plane2 = snapshot $Plane001
prov1 = #{} -- empty bitarray
intersectFrames = #()
getFaceSel = getFaceSelection
setfmID = setFaceMatID
for t in 0 to 50 do
at time t
if (intersects plane1 modNode) do append intersectFrames t
local selFaces = getFaceSel plane1.mesh
if selFaces.numberset != 0 do prov1 += selFaces
for f in prov1 do (setfmID plane2 f 2)
plane2 = (convertto plane2 Editable_Poly)
plane1.baseobject = plane2
delete plane2
format "frames at intersection = %\n" intersectFrames
Reply to Branko Živković
Willian Kim
I'm testing ... and everything went right ... when I grow up I want to be like you ...
lol =D
very thanks
Little trick
This works with your file. Solution for Editable Poly object
with redraw off
max create mode
plane1 = $Plane001
for t in 0 to 50 do
at time t
delete plane2
Willian Kim
yes, I will use this separation to paint a map of footprint ... I do have one more question ... could somehow know which frame each collision that occurs?
thanks in advanced
this works only if you use editable_mesh object not editable_poly.
open the file in attachments and run this code
plane1 = $Plane001
plane2 = $Plane002
for f in 0 to 50 do
--sliderTime = f
at time f
--uncomment *line 14* i if you want to select faces
--plane2.selectedfaces = prov1 --
for f in prov1 do setfmID plane2 f 2
update $
Willian Kim
So, two question.
when I use "prov = $. selectedFaces the BitArray" and then ask prov.count it returns the total number of faces and not the number of items in the array ...
above the editablepoly I have a Vol. Select modifier and when I use "prov = $.selectedFaces as bitarray" he can not get the selected faces anyone have any idea ?
Reply to Willian Kim
First if you use array and you want to know the count then use:
arr = #(1,5,8,10)
arr.count
-->4
But for bitarray you need to use:
bitarr = #{1..5,10,16}
bitarr.numberset
-->7
Next time say if you use modifiers or not :)
For the editpoly mod you can use various methods
Read mxs help, topic Edit_Poly : Modifier
EditPolyMod.GetSelection $.modifiers[#Edit_Poly] #Face
--or
EditPolyMod.GetSelection $.Edit_Poly #Face
--or
$.modifiers[#Edit_Poly].EditPolyMod.GetSelection #Face
--or
$.Edit_Poly.EditPolyMod.GetSelection #Face
--or
$.modifiers[#Edit_Poly].GetSelection #Face
--or
$.Edit_Poly.GetSelection #Face
Are you preparing some new script or just playing with modifiers?
Share at least one screenshoot :)
Willian Kim
Hey... I am trying to solve a problem ... I'll try to explain ... I have a plane with a modifier "Vol.Select", and would like to collect the faces that "Vol.Select" select ... I select only the latest faces and not all. would like to create an ID for each selection group that creates the Box Plane ... you get the idea? I'm sending the file to the test ...
was trying something like...
for f in 0 to 50 do
sliderTime = f
prov1 = #()
tst = $.VolselectMod.GetSelection #Face ---- This line is not working ... not found the correct code
	append prov1 tst
prov1
p.s. I'm a begginer... help are welcome
Willian Kim
lol.
I will try ...
very thanks
PolyOp Method
This is the same [PolyOp Method]
prov = polyop.getFaceSelection $
polyop.setFaceSelection $ #{}
polyop.setFaceSelection $ prov
max views redraw
Swordslayer is faster :)
Cheers!
You can't convert as integer but you can convert as bitarray
$.SetSelection #Face #{}
$.SetSelection #Face prov
Vojtech Cada
Hi, did you try to cast it to bitarray? Like this:
$.EditablePoly.SetSelection #Face prov -- or $.selectedFaces = prov
