Select by visibility
By caglar · 2020-08-12
i have a scene that contains millions of objects, some of them are Visibility 0 in object properties
i only see them when i go Wireframe view, i have to select them all and delete
is there any script or code for do that?
note:they're not visibility box checked or not. its visibility 0.0
Yep. I forgot about this and tested only with objects with Visiblity set to arbitrary value.
This will work with all objects:
	select (for o in objects where (getVisController o) != undefined and o.visibility.controller.value == 0.0 collect o)
	delete (for o in objects where (getVisController o) != undefined and o.visibility.controller.value == 0.0 collect o)
This will select all objects with visibility = 0.
	select (for o in objects where o.visibility.controller.value == 0.0 collect o)
This will delete all objects with visibility = 0.
	delete (for o in objects where o.visibility.controller.value == 0.0 collect o)
Reply to miauu
Panteleev Sergey
mxs reference:
By default, there is no controller assigned to the visibility track. Accessing the .controller property of the visibility track will throw an error.
