Select by material
By Willian Kim · 2012-05-28
I need a help, I tried a few ways ... As you select an object by material "Select by material" is there a code?
Comments (8)
Or if you want to have same wirecolor but different from others objects
then use next code
for m in scenematerials do
	(refs.dependentNodes m).wirecolor = random black white
I understand that you want to change wirecolor to the objects that
share same materijal. If i'm wright then use this
	local objArr = refs.dependentNodes m
	for o in objArr do o.wirecolor = random black white
smart select by material
Try to modify this because i plan to use it in the next update of
Select Objects By BitmapTex script.
fn getGrandParent obj = (while obj.parent != undefined do obj = obj.parent)
if selection.count == 0 then (messageBox "You must select at least one object!" title:"Warning" beep:false) else
local obj = selection[1]
if obj.material == undefined then (messageBox "This object don't have assigned material!" title:"Warning" beep:false) else
local mat = obj.material
local objArr = refs.dependentNodes mat
if objArr.count == 1 then (messageBox "Material of this object is unique!" title:"Warning" beep:false) else
for itm in objArr do
if (isGroupMember itm == true and isOpenGroupMember itm == false) do
local grandParent = getGrandParent itm
try (setGroupOpen (getGrandParentName itm) true) catch()
) ; select objArr
Reply to Branko Živković
Willian Kim
Hey Barigazy, thanks for the help, but could not get in my need, see if you can help me ...
I am writing a tool and want to put color in random objects in the scene by the material objects with the same material have the same color ... see if I'm in a right way... lol
fn matWire =
matObj = #()
for obj in objects do (
m = obj.material
appendIfUnique matObj m
for obj in objects do(
for x = 1 to matObj.count do(
if matObj[x] == obj.material then(
obj.wirecolor = random black white
Reply to Willian Kim
Use tags < code>your code here .. < /code> when you post next time.
It's easyer to read, like this
fn matWire =
	local matObj = #()
		m = obj.material
