select all the children?
By nycwtorres · 2009-01-26
how do I select an object AND all it's children (objects linked to it) in the hierarchy?
Comments (7)
mariokart64n
sorry for the bump, I had a need to find children and wrote a function that does so
please feel free to optimize and improve the function
fn grabchildren abone = (
childArray = #()
tempArray = #()
for z = 1 to abone.children.count do (
append tempArray abone.children[z])
while tempArray.count!=0 do (
abone = tempArray[tempArray.count]
append childArray abone
deleteitem tempArray tempArray.count
append tempArray abone.children[z]))
return childArray
*example
grabchildren $Bone001
and it would return all its children
juxtapOZ
Well it's been a while since this post (now fluent in maxscript), but i discovered this sweet little command shortly after, which saves you from having max run through a for loop just to find the hierarchy.
select $/...*
or even,
select $...*
Go figure, it's listed under a page titled "Pathname Literals" rather than simply "hierarchy" or something else pleasantly easy to find.
http://www.cgplusplus.com/online-reference/maxscript-reference/source/pa…
hopefully this saves any newcomers a few more strands of hair. :)
martinskinner
Does this do the trick? -
for i in selection do
selectmore i.children
I'm not 100% clear as to what you are trying to do, but this ran through selected objects and added to the selection all of their children whilst retaining the initial objects as selected.
Hope it's of help.
Martin
www.martinskinner.co.uk
though re-reading the above post it's pretty much the same script minus the if clause and not packaged as a function. So are either of them what was initially wanted?
juxtapOZ
yeah i've run into the same problem...time and time again.
if you just want a hotkey, no problem.
customize user interface > keyboard tab >  ...and search for Select Children
then just set a hotkey (i have mine set to Ctrl + PgDown)
i think max's default for Select Child is PgDown.
But the frustrating part is trying to call this action/selection from MaxScript; for automating hierarchical selections to run any number of procedures on that array.
The reason for this, is because Max's keyboard commands does not appear to be accurately reflexed in MaxScript commands.
select $.children (acts like Keyboard Command / Select Child)
select $.child (is an unknown property)
Turning on echo all or the macrorecorder while performing the Keyboard Command, rarely serves its purpose b/c it doesn't really show you what Max is actually receiving.
You're likely to recieve something about actionman, which, as far as i know, is not a valid script command, unless you want to save/load the .kbd file.
i'm still trying to get used to MaxScript *hence the frustration* (so please correct me if i'm wrong), but you'll have to recreate the key board command by cycling through a selected node's children's children's grandchildren's etc... with a FOR loop, to populate the array.
edit:
ok...starting to make a little more sense now :)
    function selectHierarchy =
    for p in selection do
    if p.children != undefined do
    selectmore p.children
    selectHierarchy()
martinskinner
selectmore $.children
-- this adds the children of the selected object to the selection.
but of course you could just double left click on the parent object and that selects both it and all it's children in the hierarchy... :)
Reply to martinskinner
nycwtorres
almost.. that only selects one level of children. I want to select ALL the children
