I have a script that auto-maps planes based on name:
local img_path = "C:/Users/Username/Documents/filenameblahblah/"
for p in $Plane* do (
addModifier p (uvwMap()) -- remove these 2 lines if the planes
convertToMesh p -- already have texture coordinates
local num = substring p.name (p.name.count - 2) p.name.count
local mat = standardMaterial()
mat.diffuseMap = bitmapTexture filename:(img_path + "Diffuse" + num + ".png")
mat.opacityMap = bitmapTexture filename:(img_path + "Alpha" + num + ".png")
p.material = mat
However, this is only of use to me if both sides are mapped visibly. In other words, having "2-Sided" checked under "Shader Basic Parameters" in the material editor.
I'll need to do this with thousands of planes, so I'd really like to integrate "toggle all materials 2 sided" with this script if possible. A separate script would also do.
(By the way, my Maxscript Listener isn't working at all, but that's a question for another thread. Still getting in the way of me figuring this out.)
Many thanks,
~Sten
Progress...
OK, so in the meantime I got Listener working, and found that "meditMaterials[22].twoSided = on" is what I needed. I put it on the last line and it seems to be working.
...Though with a mystery. When I use the eyedropper within the Material Editor to actually bring in one of my maps, the "2-sided" box is NOT checked. Even though it acts 2-sided.
I also realized that no matter which plane's material I bring into the editor, it always says that it is mapped with "Alpha001"/"Diffuse001" when it should in reality be something like "Alpha018"/"Diffuse018."
I'm having a hard time understanding how mapping planes with a script is different than doing everything through the material editor. I'd like to know more about the differences.
