scripting controllers
By intensenex · 2011-05-20
I am basically trying to script an object(box) to move down when another object moves up. i am trying to get it simulate in real time just as when position controller is applied to object to move along with another object. I need to move update automatically in viewport. Can you tell me more about how to script controllers.
Graph
yeah but the question is what to take as an origin if absolute movement is wanted or if he wants to increment (wich i'd suggest(in both z directions)), but for that you'd need a startPoint so you can get the vectorLength between the original position at time of assignment and current one.. wich of course has to be reAssigned/applied when the direction changes
hope that made enough sense (late here)
br0t
I think you can very well do this using "Wire Parameters" from the Animation Tab.
Using a simple expression you could invert the Z Axis so the slave box will move down when you pull the master up.
Reply to br0t
intensenex
It worked
Thanks a lot i did not know about wire parameters and it did the trick.
