Hi there,
I am in the process of writing a scripted plugin which can do the following;
create a splineshape between two different nodes. When creating the plugin object, I need to initialize a node picking tool, which I cannot seem to get done. Second, when the spline is generated, it needs to be updated when the linked nodes are moved. I suppose this is done using shape instances? I just cannot find any reference to start from.
There is so little information about this in the help files, I figured I would post it in here.
I currently have this as a base for my plugin;
plugin shape Path_segment
classID:#(0x48238272, 0x48206285)
extends:line replaceUI:true version:1
category:"Carmatools"
local last_n1pos,last_n2pos,thesegment
parameters main rollout:params
node1_param type:#node ui:node1
node2_param type:#node ui:node2
rollout params "Params"
label node1_label "Node1:" across:2 offset:[0,3] align:#right
pickbutton node1 autodisplay:true
label node2_label "Node2:" across:2 offset:[0,3] align:#right
pickbutton node2 autodisplay:true
on node1 picked obj do
node1_param = obj
node1.text = obj.name
last_n1pos = obj.pos
on node2 picked obj do
node2_param = obj
node2.text = obj.name
last_n2pos = obj.pos
tool create
thesegment = splineshape pos:node1_param.pos
addKnot thesegment 1 #corner #line node1_param.pos
addKnot thesegment 1 #corner #line node2_param.pos
updateShape thesegment
thesegment
obviously the tool section is a dummy and needs the proper code for my goals.
Has anybody done anything similar or can anybody help me out? Perhaps some of you have seen a similar script before and can point me in that direction?
why you need to make this as plugin? that's mission impossible. you can made it as mouse tool or macro script.
I have been able to invoke the node picking tool, and can generate a spline between two nodes. The spline vertices however are not properly linked with the nodes, so the splineshape doesn't update when I move the nodes. Somehow I feel I should work with link contraints rather then updating the splineshape... This is what I currently have. Help still appreciated! :)
