I would love to have script to rename vrayproxies to their file reference.
For example:
VRayProxy01
should be renamed to
VRayProxy01_iTrees-02-Hawthorn_04
Is this possible???
By cybertect · 2016-01-27
For example:
VRayProxy01
Is this possible???
If you want to change names of selected VrayProxies do this:
if you want to apply it to all VrayProxies in scene try this:
Cheers
Pixamoon
Copy V-ray Render settings from one to another scene
Hi guys,
I have two v-ray scene files . I have all the lighting and rendering setup with one scene with huge number of polygons. So, To optmize this, i have copied all the required models and characters to another scene. I have copied existing lights to another scene with the same settings (manually edited same values in other scene).But, I am unable to render the frame with the same output. Please suggest how do i suggest Same v-ray render settings to another file.
VRay Render settings
how about saving it as render preset and loading that preset in other max ?
POSSIBLE....
