Sign in
Script to find the dimensions of an image
By scottparris · 2014-09-16
Is this even possible?
Browse to a folder, find the one jpg image inside the folder, and set the render output size to match the photo dimensions.
Then assign that jpg image to material slot #23 and # 24.
Thank you! Works perfectly.
That's awesome!
Thank you, but is there any way to assign the jpg as a bitmap texture and not assigned to the diffuse slot inside a standard material? I'm using the bitmap as an environment background and not a scene material.
Thank you!
miauu · 2014-09-16
Run the script.
Select the jpg file.
	jpgFilePath = getOpenFileName types:"JPG(*.jpg)|*.jpg|All|*.*|"
	jpgInfo = getBitmapInfo jpgFilePath
	renderWidth = jpgInfo[3]
	renderHeight = jpgInfo[4]
	mat = standard diffuseMap:(Bitmaptexture fileName:jpgFilePath) showInViewport:true
	meditmaterials[23] = meditmaterials[24] = mat
barigazy · 2014-09-16
Yes U can
meditmaterials[23] = meditmaterials[24] = environmentmap = (Bitmaptexture fileName:jpgFilePath)
