Hi all and happy new year!
Somthing tells me this 'could' be easy...
I am trying to make a script that will automatically change every material that is in the current scene so they do NOT 'show standard map in viewport'. Does anyone have an idea on the code for this?
Some texture maps can have nested texture maps in them. But it would be tedious to go through all of them turning them off.
A workaround is to force the material to on, then off.
Thanks alot. The code below is working except for one problem. If there is no diffusemap in the slot, the script halts. Would you know how to add a check to see if a diffuse map exists before proceeding?
for object in selection do
if (classOf object.material == Vraymtl) then
object.material.showInViewport = off
showTextureMap object.material object.material.diffusemap off
else if (classOf object.material == Multimaterial) then
for b = 1 to b = object.material.numsubs do
if (classOf object.material.materialList[b] == Vraymtl) then
updateToolbarButtons()
here's a script.
source : http://www.polycount.com/forum/showthread.php?t=76143
if (classOf object.material == Standard) then
if (classOf object.material.materialList[b] == Standard) then
