Hey everyone,
I'm looking for any help I can get (pointers, tips, links, suggestions, anything) to accomplish the following:
(Also see attached Max file) Say have have 4 copies of a box. Each copy has a turbosmooth modifier and a spherify modifier. I want to link a slider manipulator to each of their TurboSmooth viewport iterations, a slider to their TurboSmooth render iterations and a slider to their spherify percentage.
As of right now, I have to link the slider to each object individually by going to the Schematic View, selecting the slider (eg. TurboSmooth Viewport Iterations), right clicking, selecting "Wire Parameters", Object/Value, clicking out in space to get the dialog to pop up, then searching through to find the right objects (out of hundreds of objects in my scene), expand all of their modifiers, click on viewport iterations and finally link them... 1 at a time. I've tried this the other way around too: Select all of the boxes first and try to wire them to the slider all at once... it only does 1 box unfortunately.
Something like this doesn't sound that bad when there are only a few object. But when there are maybe 100-150 (copies of) objects that I need to control with a few sliders (that all have the same modifier stacks), this can get very time consuming.
I'd like to script it but with linking sliders to object modifier values, I don't even know where to begin. Would be great if I could select a group of objects and tell them ALL to link to one slider and then it asks what modifier property I want to link.
Any help would be greatly appreciated! I've searched for several hours on the subject and thus far, have come up empty handed. So anything you can share will be helpful. Even if it's just pointing me to the right thread/link!
Try this
Hope it help tho, I cant open your max files, coz Im in lower max version right now.
Thanks for the response!
I didn't think about getting it done this way. I think it could potentially work! Though as of right now, it seems like the script works for the spherify modifier but not the render iterations. Or it worked once for render iterations but then wouldn't work again. I'm going to play around with it and see if I can get it to work. But again, thanks for the response! Greatly appreciated!
