Script Speed
By Goonda · 2012-09-06
I have written a script which will do something like this:
Detach faces applied with material whose name ends with "_alpha" (material name) to new objects, and put those new objects inside a group called "Alpha_blending_mesh".
The script is running perfectly fine and doing exactly what I intend it to do. But the problem is it is running fast only the first time....from the next time it is taking too long (specially for complex scenes with too many objects).....again if I restart max it is running fast for the first time. I am not sure what is happening once I run the script for the first time....which is making  it slow from the next attempt!! I have tried gc()....clearundobuffer()...nothing is working!! I have saved the files after I ran the script once....restarted max and ran it again...it again works fast for the first time....so the problem is not in the file...something is eating up the memory after the first run!!
I have written this by following this forum but since it is my first script it might look very clumpsy and funny :P.....here is the script:
undo off
-- delete previous groups named "Alpha_blending_mesh"
objgroup = #()
for o in helpers do
if o.name == "Alpha_blending_mesh" then
append objgroup o
if objgroup.count != 0 then
for i = 1 to objgroup.count do
ExplodeGroup $Alpha_blending_mesh
--will merge all vertices with threshold 0.001 if the obj is not inside a group
fn weldverts obj =
result = isGroupMember obj
if result == false do
$.weldThreshold = 0.001
polyop.weldVertsByThreshold obj #All
-- Collect objects from scene in working list
workingObject = #()
for o in Geometry do
if classof o != bonegeometry do
append workingObject o
fn Singlemat obj =
mat = obj.material
TextureFileName = "notexture"
if (classof obj != bonegeometry) and (mat != undefined) and classof mat.diffuseMap == Bitmaptexture do
stringSS = mat.name
stringcount = stringSS.count
if stringcount > 6 then
TextureName = substring stringSS (stringcount - 5) ((stringcount - 5) + 6)
if TextureName == "_alpha" do
objname = obj.name
stringTT = objname as string
stringTTcount = stringTT.count
if stringTTcount > 6 then
ObjnameTT = substring stringTT (stringTTcount - 5) ((stringTTcount - 5) + 6)
if ObjnameTT != "_alpha" do
obj.name = objname +"_alpha"
fn detachFBI obj =
objname = obj.name
ids = obj.material.materialIDList
for id in ids do
obj.selectbymaterial id
_faceSel = polyOp.getFaceSelection obj
polyOp.detachFaces obj _faceSel delete:true asNode:true name: (objname +"_tempdelface")
select $*_tempdelface*
$.name = objname
-- Run though all objects in array and detach them
for o in workingObject do
(mat = o.material
if (mat != undefined) and (classof mat == Multimaterial) do
select o
detachFBI o
delete o
--assigning single material to all object (removing unused multimaterials)
for o in geometry where isKindOf o.material multimaterial and (classof o != bonegeometry) do
-- Get face material ID from face 1
local id = getFaceMatID o.Mesh 1
-- Assign that material
o.material = o.material[id]
-- Run though all objects and check for "_alpha" in diffuse map, rename objets as *"_alpha"
for g in geometry do
select g
Singlemat g
--group as "Alpha_blending_mesh"
clearselection()
select $*_alpha
if $ != undefined do
group selection name:"Alpha_blending_mesh"
--attaching same named objects and welding vertices by 0.001 thresold
newworking = #()
for o in geometry do
if classof o == editable_poly and classof o != bonegeometry do
append newworking o
i = 1
while i <= newworking.count do
b = newworking[i]
j = i + 1
while j<= newworking.count do
if (newworking[j].name == b.name) then
b.attach (newworking[j]) b
deleteItem newworking j
select b
weldverts b
j = j +1
i = i + 1
--set final selection to group "Alpha_blending mesh, tool to 'move' mode, panel to 'modify' mode"
groupName = "Alpha_blending_mesh"
grp = getNodeByName groupName
if isValidNode grp and isGroupHead grp do
select $Alpha_blending_mesh
toolmode.commandmode = #move
setCommandPanelTaskMode mode:#modify
Comments (14)
I not tried the script.
Put locals weldbythresh, detachF and getMatID inside "on btn pressed do" event.
Try this code
I add some stuff in your code.Need to optimize more but not have
time right now.
if getCommandPanelTaskMode() != #create do setCommandPanelTaskMode mode:#create
undo off
local objgroup = #()
local workingObject = #()
local newworking = #()
for o in helpers where o.name == "Alpha_blending_mesh" do append objgroup o
if objgroup.count != 0 do for i = 1 to objgroup.count do ExplodeGroup $Alpha_blending_mesh
fn weldverts obj =
local result = isGroupMember obj
for o in Geometry where not isKindOf o bonegeometry do append workingObject o
fn Singlemat obj =
local mat = obj.material
local TextureFileName = "notexture"
local stringSS = mat.name
local stringcount = stringSS.count
if stringcount > 6 do (TextureName = substring stringSS (stringcount - 5) ((stringcount - 5) + 6))
local objname = obj.name
local stringTT = objname as string
local stringTTcount = stringTT.count
if stringTTcount > 6 then (ObjnameTT = substring stringTT (stringTTcount - 5) ((stringTTcount - 5) + 6))
if ObjnameTT != "_alpha" do (obj.name = objname +"_alpha")
fn detachFBI obj =
local ids = obj.material.materialIDList
local detach = polyOp.detachFaces
for id in ids do
_faceSel = obj.selectedfaces as bitarray
detach obj _faceSel delete:true asNode:true name: (objname +"_tempdelface")
$.name = objname
for o in workingObject where (o.material != undefined) and (classof mat == Multimaterial) do (detachFBI o ; delete o)
for g in geometry do (Singlemat g)
clearselection()
select $*_alpha
if $ != undefined do ( group selection name:"Alpha_blending_mesh")
for o in geometry where classof o == editable_poly and classof o != bonegeometry do append newworking o
i = 1
b = newworking[i]
j = i + 1
if not (newworking[j].name == b.name) then (j = j +1) else
select b
weldverts b
i = i + 1
if isValidNode grp and isGroupHead grp do (select $Alpha_blending_mesh)
free objgroup ; free workingObject ; free newworking
Its working fast now....but something with the material assignment gone wrong.....lets see if I can debug that!! Thanks a lot!!
Only one question....do we always need to mention "local" for local variables....I thought it takes local automatically...unless we mention it as "global"??
Reply to Goonda
Willian Kim
I tried to optimize a bit by
I tried to optimize, I deleting the actions selection ... over the script of Barigazy ...
	undo off
		--- Variables
		--- Functions
		fn weldverts obj =
				obj.weldThreshold = 0.001
		fn Singlemat obj =
		fn detachFBI obj =
			for id in ids do
			tempDelFaces = for o in objects where matchPattern (o.name) pattern:"*_alpha" collect o
			tempDelFaces.name = objname
		--- Script
		alphaObjs = for o in objects where matchPattern (o.name) pattern:"*_alpha" collect o
		if alphaObjs.count != 0 do (	group alphaObjs name:"Alpha_blending_mesh")
		i = 1
			b = newworking[i]
			j = i + 1
					weldverts b
			i = i + 1
Reply to Willian Kim
Goonda
I don't know what is the problem, both barigazy and kimarotto's script is ruining my material assignments in multitextured objects.....but I got the point from your scripts, on how to make it fast....so i added the "local" before the variables and freed the arrays in my old script....it is now working fine and fast!!
	undo off
		for o in helpers do
				append objgroup o
		fn weldverts obj =
		fn Singlemat obj =
				local TextureName = substring stringSS (stringcount - 5) ((stringcount - 5) + 6)
						local ObjnameTT = substring stringTT (stringTTcount - 5) ((stringTTcount - 5) + 6)
		fn detachFBI obj =
			for id in ids do
			$.name = objname
		(	local mat = o.material
				select o
				detachFBI o
				delete o
		-- Run through all objects and check for "_alpha" in material name, rename objets as *"_alpha"
			select g
			Singlemat g
		clearselection()
		select $*_alpha
					append newworking o
		i = 1
			b = newworking[i]
			j = i + 1
					select b
					weldverts b
					j = j +1
			i = i + 1
	free objgroup ; free workingObject ; free newworking; gc()
Reply to Goonda
try this
try(destroyDialog ::testRoll)catch()
rollout testRoll "Test"
local weldbythresh = polyop.weldVertsByThreshold
local detachF = polyOp.detachFaces
local getMatID = getFaceMatID
fn weldverts obj thresh:0.001 = --will merge all vertices with threshold 0.001 if the obj is not inside a group
if not isGroupMember obj do
obj.weldThreshold = thresh
weldbythresh obj #All
fn detachFBI obj =
for id in ids do
detachF obj _faceSel delete:true asNode:true name:(objname +"_tempdelface")
for o in geometry where matchPattern o.name pattern:"*_tempdelface*" do o.name = objname
fn Singlemat obj =
if (isKindOf o bonegeometry) and (mat != undefined) and isKindOf mat.diffuseMap Bitmaptexture do
local TextureName = if stringcount > 6 do substring stringSS (stringcount - 5) ((stringcount - 5) + 6)
stringTT = obj.name
ObjnameTT = if stringTTcount > 6 do substring stringTT (stringTTcount - 5) ((stringTTcount - 5) + 6)
if ObjnameTT != "_alpha" do obj.name = objname +"_alpha"
button btn "Do The Job!" pos:[5,5] width:100 height:18
on btn pressed do
undo off
local objgroup = for o in helpers where o.name == "Alpha_blending_mesh" collect o
if objgroup.count != 0 do (for i = 1 to objgroup.count do ExplodeGroup i)
local workingObject = for o in Geometry where isKindOf o bonegeometry collect o
if workingObject.count != 0 do
for o in workingObject where o.material != null and isKindOf o.material Multimaterial do (detachFBI o ; delete o)
for o in geometry where isKindOf o.material multimaterial and (isKindOf o bonegeometry) do o.material = o.material[(geteMatID o.Mesh 1)]
for g in geometry do Singlemat g
clearselection()
local alphaArr = $*_alpha as array
if alphaArr.count != 0 do (group selection name:"Alpha_blending_mesh" ; free alphaArr)
local newworking = for o in geometry where isKindOf o editable_poly and isKindOf o bonegeometry collect o
i = 1
b = newworking[i]
j = i + 1
weldverts b
i = i + 1
local grp = getNodeByName "Alpha_blending_mesh"
if grp != undefined and isGroupHead grp do select grp
createDialog testRoll 110 28 style:#(#style_titlebar, #style_sysmenu, #style_toolwindow)
Willian Kim
see
Goonda
Now looking fine :)
	undo off
		objgroup = #()
		for o in helpers do
				append objgroup o
		fn weldverts obj =
		workingObject = #()
		fn Singlemat obj =
			mat = obj.material
				stringSS = mat.name
					objname = obj.name
		fn detachFBI obj =
			objname = obj.name
			for id in ids do
			$.name = objname
		(	mat = o.material
				select o
				detachFBI o
				delete o
			select g
			Singlemat g
		clearselection()
		select $*_alpha
		newworking = #()
					append newworking o
		i = 1
			b = newworking[i]
			j = i + 1
					select b
					weldverts b
					j = j +1
			i = i + 1
Willian Kim
please put your code betwen
<code>
