Script problem
By lunar1369 · 2009-05-28
A simple script to rattle through the material editor and copy the diffuse map to the bump map. Script with errors below. Any help would be appreciated.
for i = 1 to 24 do (
for t = 1 to meditMaterials[i].materialList.count do (
meditMaterials[i].materialList[t].bumpMap = meditMaterials[i].materialList[t].diffuseMap
-- Syntax error: at ), expected
-- In line: )
real08121985
Cause the listener interprets your code each time you hit return.
-- So this works:
for i=1 to 3 do ( print i )
-- But this not:
for i=1 to 3 do (
	do print i
real08121985
Your code works for me, I only added a check if the material is a multimaterial.
	local MultiMatCount = undefined
	try MultiMatCount = meditMaterials[i].materialList.count catch()
	if MultiMatCount != undefined do (
		for t = 1 to MultiMatCount do (
Note that you should send your code within code-tags for better formatting (look at the lower end of http://scriptspot.com/filter/tips).
Reply to real08121985
lunar1369
Yoodaman! How come it throws errors in the listner but not when you run the script through "Run Script"?
