Script on custom attribut controller problem
By TSystem · 2019-03-25
Hi, Before to start with my problem, thanks for your website, really usefull ! I'm working on a simple script to batch a controller with several options, it work perfectly on a classic controller like a position but not on a custom attribut and i can't find my error. Please find bellow a short version of my script ( this part bake controller )
<code>
fn bakeMe ctrl fromRange:animationRange.start toRange:animationRange.end  = (
    fromRange = fromRange as time
    toRange = toRange as time
    if (superclassof ctrl.controller) != FloatController do -- ctrl doit-être un controler de type float
            print "Only work on FloatController superClass"
            return false
    undo "BakeControler " on (
        tmpVal=#()
        try (
            -- record value
                for i = fromRange to toRange do (
                    at time i (
                        append tmpVal ctrl.controller.value
            -- assign new controller
                ctrl.controller=linear_float()
            --applying value to the new controller
                    at time i (
                        numID =((i.frame)+1-(fromRange.frame as integer)) as integer
                        with animate on (
                            ctrl.controller.value = tmpVal[numID]
        )catch(
            format "*** BakingError: % ***\n" (getCurrentException())
 bakeMe $.position.controller[1]   -- Work perfeclty
bakeMe bakeMe $.baseObject.Custom_Attributes.param1 -- Crash with Unknown property: "controller" in 6.69115 ( value )
</code>
Thanks for your help
TSystem
Got my solution on another forum watting to be approved here.
So if it's can help someone :
fn bakeFloatController c type:#linear range: step:1 = if iskindof c FloatController do
if range == unsupplied do range = getTimeRange c
_c = if type == #linear then linear_float() else bezier_float()
for t = range.start to range.end by step do at time t
k = addNewKey _c t
k.value = c.value
replaceinstances c _c
numkeys _c
