Hello
I'm working on a script nowdays, but I have got some problem with the Rollouts...
I made a very simple script to show you what is my problem. My goal was to create a button, wich can create a new rollout. The most interesting, that the error message is only in the first run of script, when I run this script second time, it's work.
The script:
rollout MENU "MENU"
button On01 "On" width:90 pos:[10,10]
button Off01 "Off" width:90 pos:[10,40]
on On01 pressed do
addRollout Rollout01 menu_windo
on Off01 pressed do
removeRollout Rollout01 menu_windo
rollout Rollout01 "Rollout"
button Button01 "Button" width:90 pos:[10,10]
menu_windo = newRolloutFloater "Rollout" 150 180
addRollout MENU menu_windo
And I got this error message when I run this script first time:
"Type error: CreateDialog requires RolloutClass, got: undefined"
It's a picture about the happenings: https://dl.dropbox.com/u/1152958/script_error.jpg
Thanks your helps in advance.
Matyrix
Comments (8)
just testing
thanks Christopher.
I used the [code] tags, but beacause of the spaces, i got some wierd stuff for a maxscript code. lol
I ll use the <code> tags. :D
Ahh. I see. I bet you activated the rich text editor right? It adds in all kinds of html formatting that breaks the code snippet.
I find the best way to work most of the time is to just use the simple text box, any links you type will turn to actual links w/o any [url] tags or anything like that and any code pasted in [ code ] blocks will highlight correctly.
On occasion if I really need formatting I'll use rich text...
like this it's working perfectly: 😉
Thank you very much, it works :)
Edited your post to add code tags for syntax highlighting...
http://www.scriptspot.com/forums/scriptspot-how-to/how-to-post-code-snip…
it's normal.
Don't forget that maxscript is reading line by line, like you do when you read a book.
In your script you ask it to add or remove rollouts, from the rolloutFloater.
But at this time, it doesn t know therolloutFloater, because you create it later in the script.
to prevent this, you should create the rolloutFloater before the rollouts. like this
rollout MENU "MENU"
on On01 pressed do
on Off01 pressed do
Thanks your comment!
Unfortunately your corrected script is not work... I tried to run it on three different computers, but the first time always send error messages... Of course the second run is always works, but it's not a good solution...
What's the wrong?... I don't understand...
