i wonder
when i worked with script , there is problem often
then i have to reopen manually
i would like to reopen script automaticly when script was error
is there good idea ?
By dussla · 2012-07-27
i wonder
I have to see the code.If
If ... then ... else is for 2 conditions.
Maybe the code can be fixed and the errors will not occurs.
Try with this:
So, the script have to be unencrypted.
IF you want you can send me the script and I will try to "fix" it.
i wonder some
there is 2 conditions
1. try ( destroy ~)
2. try ( if reopen becoming error)
pls can you make 2 condition possible in 1 script ?
