Hi All,
i need some help. I need to scatter evenly an object on a poly surface. So the object instaces need to keep same distance between each other and a strict lines and columns but on the way if it would be turned 45 degree, similar as can see on the a attached picture. The surface is curved in many ways so I cant take its edges or faces the base of the scatter. And also not possible to redo it as nurbs.
I need to put thousands of instances to the surface.
Maybe I just dont find the right tool, maybe sombody just could tell me how to do that?
Thank you for the help in advance.
(I use max 2012,64bit)
Scatter evenly on curved, not even surface
By Manfred · 2013-02-15
- pattern.jpg — pattern.jpg216 KB
Multiscatter is a cool tool thank you for mention that
but i just cant get the right settings. I tryed a regular pattern settings using mapping but it just dont get the right result. Thank you anyway.
What about using multiscatter for that? See Multiscatter :: Pattern
