Saving only diffuse channel from a exr sequence
By zahid hasan · 2022-12-24
Hi everybody. Is there a way to Save only diffuse channel from an Exr sequence. The thing is, I rendered using vray with dnoiser channels and now the files are too heavy to store or easy compositing.Do I need to use videopost? Can anybody help to make a scirpt?
ps. using openbitmap() which works. But I realized I need the Z-depth channel too. This command seems not to load z-buffer channels.
zahid hasan
I can use openbitmap() to load and save the exr files. But cannot load the Z-depth channel to save with it. Am I using the wrong function?
