The function saveMaxFile does not save under 3ds Max 2016.
The function should work as before because the documentation has not changed:
http://help.autodesk.com/view/3DSMAX/2016/ENU//index.html?query=saveMaxF…
Feel free to test the code below if you are currently using/testing 3ds Max 2016:
clearlistener()
format "I am using 3ds Max %\n\nLet's test the saving function!\n\n" (((MaxVersion())[1]/1000) + 1998)
local i = 2013, myPath = "C:\Autodesk\3dsMax\Bug\tooThe.max"
while i <= 2016 do
local b = saveMaxFile myPath saveAsVersion:i clearNeedSaveFlag:true useNewFile:true quiet:true
if b then
format "file saved under: 3ds Max %\n" i
format "file not saved under: 3ds Max %\n\n" i
i += 1
You should get this response in the Listener Window:
I am using 3ds Max 2016
file saved under: 3ds Max 2013
file saved under: 3ds Max 2014
file saved under: 3ds Max 2015
file not saved under: 3ds Max 2016
maybe max 2016 is default so skip saveAsVersion:i
or use saveAsVersion:default ?
I checked maxscript help and there is only saveAsPrevious: So looks like you don't need to use saveAsVersion: or saveAsPrevious: when saving to current version.
