Runtime error: Error opening bitmap
By anybany · 2012-06-06
Good day.
In scene present about 120 Plane.
Each of them fix (.material.diffuseMap.bitmap). These bitmaps stored on
D:/test/ directory
When I start script
fg=#()
d=$ImagePlane* as array
for i=1 to d.count do
append fg d[i].material.diffuseMap.bitmap
appear
#($Plane:ImagePlaneFor_camera1_d0001 @ [-8.367760,14.435833,-57.738209], $Plane:ImagePlaneFor_camera2_d0002 @ [-4.387455,15.022846,-60.023422], $Plane:ImagePlaneFor_camera3_d0003 @ [0.056606,15.007589,-61.273445], $Plane:ImagePlaneFor_camera4_d0004 @ [3.998240,14.502653,-61.476524], $Plane:ImagePlaneFor_camera5_d0005 @ [8.344356,14.367958,-61.341885], $Plane:ImagePlaneFor_camera6_d0006 @ [12.190159,12.907448,-59.661415], $Plane:ImagePlaneFor_camera7_d0007 @ [15.279215,11.183224,-57.224586], $Plane:ImagePlaneFor_camera8_d0008 @ [17.782003,9.087871,-53.741268], $Plane:ImagePlaneFor_camera9_d0009 @ [19.093401,6.970782,-49.843822], $Plane:ImagePlaneFor_camera10_d0010 @ [19.223347,5.085677,-46.160961], $Plane:ImagePlaneFor_camera11_d0011 @ [18.177902,3.121782,-41.978588], $Plane:ImagePlaneFor_camera12_d0012 @ [16.083273,1.569069,-38.334175], $Plane:ImagePlaneFor_camera13_d0013 @ [12.880341,0.494181,-35.079998], $Plane:ImagePlaneFor_camera14_d0014 @ [8.797139,-0.172102,-32.559563], $Plane:ImagePlaneFor_camera15_d0015 @ [4.045238,-0.254686,-31.050558], $Plane:ImagePlaneFor_camera16_d0016 @ [-0.028758,0.181588,-30.758663], $Plane:ImagePlaneFor_camera17_d0017 @ [-4.330082,1.088176,-31.428823], $Plane:ImagePlaneFor_camera18_d0018 @ [-8.693162,2.599252,-33.330521], $Plane:ImagePlaneFor_camera19_d0019 @ [-11.734137,4.239220,-35.784580], $Plane:ImagePlaneFor_camera20_d0020 @ [-14.109169,6.173749,-39.005417], ...)
-- Error occurred in i loop; filename: D:\3ds Max 2009\Scripts\moi\bitmap array.ms; position: 71
-- Frame:
-- i: 95
-- Runtime error: Error opening bitmap: D:\pasa1\d0095.jpg
that happened????????
Comments (7)
"Bitmaptexture" id the same
"Bitmaptexture" is the same as "bitmaptex".
Theses are class names of (in your case) diffuse maps.
You can use first or second.
anybany
BARIGAZY Thank you very match for answer
All good.....
anybany
BARIGAZY Thank you for answer but
When use
____________________________________
fg=#()
for i=1 to d.count where d[i].material.diffuseMap != undefined do
append fg d[i].material.diffuseMap.name
for i=1 to fg.count do
print fg[i]
__________________________________________
Answer
"Bitmaptexture"
but not name.....
In your case
fg=#()
BITMAP NAME & FILENAME
BITMAP NAME AND BITMAP FILENAME
allusedbitmaps = getClassInstances bitmaptex
bmpNamesArr = #()
bmpFileNamesArr = #()
for b in allusedbitmaps do
append bmpNamesArr b.name
append bmpFileNamesArr b.filename
for n in bmpNamesArr print n
for p in bmpFileNamesArr print p
anybany
I want return name each bitmap in array....
If you want to get all bitmaps used in the scene just use this
allusedbitmapss = getClassInstances bitmaptex
